JDModified Posted February 1, 2009 Share Posted February 1, 2009 Quote Link to comment Share on other sites More sharing options...
sypher_44 Posted February 2, 2009 Share Posted February 2, 2009 looks nasty.... Quote Link to comment Share on other sites More sharing options...
heckler Posted February 2, 2009 Share Posted February 2, 2009 that happened to my hybrids... Quote Link to comment Share on other sites More sharing options...
supspower Posted February 2, 2009 Share Posted February 2, 2009 I dont get it..........its just a turbo..... By the way you have a big crack in it........ Quote Link to comment Share on other sites More sharing options...
stevie_b Posted February 2, 2009 Share Posted February 2, 2009 What is it? Quote Link to comment Share on other sites More sharing options...
JDModified Posted February 2, 2009 Author Share Posted February 2, 2009 Hi chaps, its the cracks. Seen it a few times usually goes hand in hand with cars loosing oil through either the turbo or engine. The oil burning generates excessive heat and the cast simply cracks. James Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted February 2, 2009 Share Posted February 2, 2009 Hope that's not my car Quote Link to comment Share on other sites More sharing options...
Branners Posted February 2, 2009 Share Posted February 2, 2009 What is it? It is the wastegate on a set of stock turbos. The cracks radiating out from the wastegate itself mean the turbo is shot and goes in the bin. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 2, 2009 Share Posted February 2, 2009 Seen a couple of these on stock J-spec turbos, but only with the crack on the RHS. Hybrids that have had the wastegate enlarged must be even weaker and more prone to cracking in that area. Quote Link to comment Share on other sites More sharing options...
stevie_b Posted February 2, 2009 Share Posted February 2, 2009 It is the wastegate on a set of stock turbos. The cracks radiating out from the wastegate itself mean the turbo is shot and goes in the bin. Ahh, I see. Looks nasty. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 2, 2009 Share Posted February 2, 2009 Many turbo reconditioning companies happily send out rebuilt units with minor wastegate seat cracking, on some turbos it's very hard to find a used casting that ISN'T cracked that looks a bit excessive though, as once the crack gets more than a thou or two wide the heat erodes it into a V shaped track. That's one advantage of externally gated turbos Quote Link to comment Share on other sites More sharing options...
