Racman Posted August 11, 2010 Share Posted August 11, 2010 Cheers fella but im skint now will keep trying different things but to be honest they are a load of shit never again will I give the yanks my money proper pissed off been without car for 2 months now just as well I got another motor I will just push it back into the garage and cover it up again Quote Link to comment Share on other sites More sharing options...
dandan Posted August 11, 2010 Share Posted August 11, 2010 Mine is going ok so far, done about 8000miles or so and looked ok about 1800miles ago. Jamie seemed to have a good one too - maybe their quality control is bad with a percentage of duff ones coming out amongst the rest. It is definitely a clutch with a poor reputation though. Sorry for the grief you are having with it Racman Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 11, 2010 Share Posted August 11, 2010 Mine's still working after over 10,000 fairly unsympathetic miles on a single. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 11, 2010 Share Posted August 11, 2010 I have mine on my Single since 2008 .. has always worked very nice. Quote Link to comment Share on other sites More sharing options...
TLicense Posted August 11, 2010 Share Posted August 11, 2010 Cheers fella but im skint now will keep trying different things but to be honest they are a load of $#@! never again will I give the yanks my money proper pissed off been without car for 2 months now just as well I got another motor I will just push it back into the garage and cover it up again Did you try changing the slave cylinder to the one recommended by Rinus? Quote Link to comment Share on other sites More sharing options...
Steve Posted August 11, 2010 Share Posted August 11, 2010 Did you try changing the slave cylinder to the one recommended by Rinus? Part number for the N/A 6 speed slave cylinder is 31470-14070. Quote Link to comment Share on other sites More sharing options...
Racman Posted August 11, 2010 Share Posted August 11, 2010 Part number for the N/A 6 speed slave cylinder is 31470-14070. If its the 21.6mm bore one yea I got one on there mines a r154 box so not sure if the part no is different as no number on the one I have got Quote Link to comment Share on other sites More sharing options...
fuldhat Posted September 30, 2010 Share Posted September 30, 2010 After getting my Southbend Stage 3 clutch.. is the same problem, though it will fully release, when pressed all the way down. But is still hard to get into 1st and reverse. Everything was changed, clutch, flywheel, bearings, snaprings, bolts. So are going to order this slave cylinder and see if that helps. But it seems the supra, was not made for changing clutches. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 30, 2010 Share Posted September 30, 2010 It's nothing to do with Supra per se. It's, as far as I can tell, down to some kits using re faced pressure plates that change the kinematics of the clutch geometry. My kit releases fine, so do the Giken ones. Don't blame Toyota, blame cheapskate clutches. There should be no need to re engineer the release mechanism!!! Quote Link to comment Share on other sites More sharing options...
fuldhat Posted September 30, 2010 Share Posted September 30, 2010 Alot of talk have been on the RPS clutches about this issue, but nothing on the Southbend and alot are using them. With Evos, 200sx`s, audi s2, Bmw M3` s, I have never heard any trouble with clutches even if you are using "different" brands, but the supra just seem to be very very picky about what works and not. Quote Link to comment Share on other sites More sharing options...
Kirk Posted September 30, 2010 Share Posted September 30, 2010 Dont suppose you offer any uprated clutch for an NA do you chris? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 30, 2010 Share Posted September 30, 2010 I don't, no, sorry. But if I was sure the demand was there an uprated new cover could be feasible. Organic plates are where you need to be for a "nice" clutch. Cerametallic are circuit race only, really. Quote Link to comment Share on other sites More sharing options...
fuldhat Posted September 30, 2010 Share Posted September 30, 2010 Chris- Have written you an email. Quote Link to comment Share on other sites More sharing options...
fastcar Posted September 30, 2010 Share Posted September 30, 2010 I have a row street max and is the same. Has been ever since I had it. Looks like will be getting changed soon then. Didn't realise they are a bad name. Quote Link to comment Share on other sites More sharing options...
fuldhat Posted October 13, 2010 Share Posted October 13, 2010 After change of the recommened slave cylinder, the problem is still the same, though maybe 5% better, and the bite point is more on/off now. I think it was the same, that where already fitted, since all the numbers on it, was the same. Quote Link to comment Share on other sites More sharing options...
fuldhat Posted November 16, 2010 Share Posted November 16, 2010 After some weeks of use, then its gotten much better, after the change of slave cylinder. So now the clutch works fine. Quote Link to comment Share on other sites More sharing options...
