Odometer and clock not working! help
adnanshah247
Does your Speedo work?
if so I had the same problem, it was the connector that goes into the back of the Odometer, I removed the cable messed about (highly technical) and then plugged it back in..... it worked!
the clock is only based on power so thats probably down to a loose connection..... oh ! like the rest of the problem :)
Rob
