Markie Posted March 27, 2005 Share Posted March 27, 2005 Hi all.. Just found out what plugs are in my car at the moment. Anyone know how good these are: HKS SUPERFIRE PLUGS S40i Also, any good way to clean plugs like these for the supras, as from the invoice it looks like they were new last April. Thanks, Marcus. Link to comment Share on other sites More sharing options...
Guest Terry S Posted March 27, 2005 Share Posted March 27, 2005 They are iridium Grade 8 plugs mate Link to comment Share on other sites More sharing options...
CJ Posted March 27, 2005 Share Posted March 27, 2005 What does grade 8 mean? How many grades are there? Link to comment Share on other sites More sharing options...
Markie Posted March 27, 2005 Author Share Posted March 27, 2005 What does grade 8 mean? How many grades are there? Same question from me Are these the best for my car? Or are them IRD24 plugs better. Link to comment Share on other sites More sharing options...
Terminator Posted March 27, 2005 Share Posted March 27, 2005 They are iridium Grade 8 plugs mate Concert quality. Link to comment Share on other sites More sharing options...
Markie Posted March 27, 2005 Author Share Posted March 27, 2005 So these plugs are good shit?? How can I clean them without causing damage to them? Link to comment Share on other sites More sharing options...
Nic Posted March 27, 2005 Share Posted March 27, 2005 So these plugs are good shit?? How can I clean them without causing damage to them? The HKS iridium plugs are some of the most expensive plugs you can buy, whether this makes them better than others is debatable. I always use HKS plugs as I can get them a lot cheaper here and rate them highly. The S40i is the middle grade of the 3 plugs that can be used on the Supra. The S35i is okay for a stock car, the S40i would be fine for intermediate mods and then the cooler grade S45i if running higher boost. I use S45i on stock turbos running 1.25bar (430hp.) You do NOT need to clean/gap them and if you do you may well damage the very fine electrode. Provided the car is running well and not missing at high boost then leave them well alone. Link to comment Share on other sites More sharing options...
Gamer Posted March 27, 2005 Share Posted March 27, 2005 I have been using a set of s40i for over a year now boosting at 1.2bar (295hp on the stock twins and now 480hp with the single) Link to comment Share on other sites More sharing options...
Nic Posted March 27, 2005 Share Posted March 27, 2005 I have been using a set of s40i for over a year now boosting at 1.2bar (295hp on the stock twins and now 480hp with the single) I found I was getting a slight mis at high boost using S40i's which was why I switched to the S45i. Probably as a result of the higher summer temperatures here and running high boost on stock twins. I guess your single will run cooler egt's than the stock twins? Link to comment Share on other sites More sharing options...
Gamer Posted March 27, 2005 Share Posted March 27, 2005 I suppose so... I have only had the single on for a few weeks now and no problems yet. Mind you 1.2bar is a conservative boost, my tuner says she really wants more like 1.5bar. Link to comment Share on other sites More sharing options...
