Manifold vaccuum question
Multics
Might be a bit of a dumb question but I want to understand something.
Let's imagine a turbocharged engine at idle, there's a vaccuum in the intake manifold. As soon as the throtlle body opens a bit, is that vaccuum transfered to the IC piping all the way to the turbo's compressor wheel?
The reason I'm asking is that I need to install a blow of valve which requires a "boost only" source. There is an unused, blocked nipple in the IC piping. I need to know if I can use this as a source for boost only pressure...
