What size fittings for Bosch fuel reg
Wez
Hey All,
I received my Bosch fuel regulator today and wondered if people knew what sizes the ports are. I am also looking for a mount of some type, any ideas?
As it came with no instructions I am also going to have a guess on the ports, please correct me if I am wrong :innocent:
Top: manifold pressire
Left : back to tank
Right : pressure sensor/gauge
Bottom : return from rail
It's a TRD one, made by Bosch for them I think. Top quality, I use these myself. Ports as Bondago rightly says. Top port is also the lock nutted adjuster for static pressure. Ports are -6 -8 and -3 (or is it -4, it's -3 I think from memory?) You can cap the gauge port if you don't need it.
Hey Chris, thats great news thanks :thumbs:
I guess this is correct :-
Top: manifold pressure -3
Left : Feed from rail -6
Right : pressure sensor/gauge -3
Bottom : return to tank -8
Wez, TBH there aint much room there to do anything unless running an after market intake manifold.
Maybe easier to modify the rail by cutting/drilling/tapping and fitting a -6an to the end, and tapping/bunging the OE regulator hole
Nice idea, I have a couple of rails in the garage I can have a play with :D
off the top of my head, Original bango at rear of rail is replaced with m12x1.25 to -6an adapter, and Fuel filter end is also m12x1.25 -6an adapter, then make up your -6an line
Thats great thanks, do you have some closer pics showing what you have done at each end :D
no pics that show it in any detail matey but ..
Removed original banjo bolt from feed end of rail, This is replaced with a M12x1.25 to -6AN fitting.
Fuel filter outlet fitted with a M12x1.25 to -6AN fitting.
Then make up a Fuel line to run between the rail and filter, 90 degree female 6AN fitting at rail side, straight 6AN at filter side.
Stock Regulator hole, tapped and fitted with fine thread bolt + copper crush washer (cant remember what size I tapped too).
End of rail was Drilled through then tapped. Fitted with M12 x -6AN fitting. Basically the Fitting depends on the size you drill and tap too
6AN fuel line to regulator, 90 degree fitting at rail side so line can be run under throttle housing easily.
  • 2 weeks later...
