DannoSupra Posted January 26, 2009 Share Posted January 26, 2009 Evening all... What different options are there to control boost with a single turbo using aem ems? Just dont want a lot of gadgets and screens in front of me anymore Cheers Link to comment Share on other sites More sharing options...
Pig Posted January 26, 2009 Share Posted January 26, 2009 Ryan advises the ECU controlling boost. I would suggest this as i dont belive you need more than 2 or 3 settings anyway. Low - for when you have to use 95 ron High - for all the time Stupidly high - when you need to risk the lift of your engine for that little extra. Link to comment Share on other sites More sharing options...
DannoSupra Posted January 26, 2009 Author Share Posted January 26, 2009 Is that with a 3way switch and solenoid? Link to comment Share on other sites More sharing options...
Ryan.G Posted January 26, 2009 Share Posted January 26, 2009 You can fit a 2 way switch which can control hi/low but you could also fit another switch which cuts the PWM feed to the solenoid and would then just give wastegate pressure depending on how it was plumbed. I normally just set it up so it works in closed loop. High switch for high boost but in the lower speeds is lower to aid with traction and then low for just low boost Ryan Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2009 Share Posted January 26, 2009 Thats how Ryan set mine up when using the AEM, works really well Link to comment Share on other sites More sharing options...
DannoSupra Posted January 26, 2009 Author Share Posted January 26, 2009 Awsome!! Cheers. Could you do the same with mine when its ready for mapping?... ... when its ready Link to comment Share on other sites More sharing options...
Ryan.G Posted January 26, 2009 Share Posted January 26, 2009 Awsome!! Cheers. Could you do the same with mine when its ready for mapping?... ... when its ready Link to comment Share on other sites More sharing options...
DannoSupra Posted January 26, 2009 Author Share Posted January 26, 2009 Nice one bud Link to comment Share on other sites More sharing options...
Marty Posted January 27, 2009 Share Posted January 27, 2009 Going to be ditching my avcr and going for aem controlled boost myself when i get my new turbo on Fancy mapping it Ryan ? Its still on it's low boost map at the mo from when i had the engine done. Link to comment Share on other sites More sharing options...
Ryan.G Posted January 27, 2009 Share Posted January 27, 2009 (edited) Going to be ditching my avcr and going for aem controlled boost myself when i get my new turbo on Fancy mapping it Ryan ? Its still on it's low boost map at the mo from when i had the engine done. I have Boost solenoids in stock guys for £40 if you need me to bring one when mapping. Marty Just let me know about 3 weeks in advanced for booking in chaps Ryan Edited January 27, 2009 by Ryan.G (see edit history) Link to comment Share on other sites More sharing options...
