d-_-b Posted January 26, 2009 Share Posted January 26, 2009 Would an airlock in the system cause the temp meter to rise then fall (after a load of noise coming from behind the passenger side dash)? Blowers will be cold, then after the noise go to temp they should be. Have read other posts about airlocks in the system, and seems to be similar effects caused from airlocks, just thought i would see if this is what everyone thinks this is what could be the cause. Quote Link to comment Share on other sites More sharing options...
d-_-b Posted January 27, 2009 Author Share Posted January 27, 2009 Anyone? Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted January 27, 2009 Share Posted January 27, 2009 Sounds like an airlock to me. Is the noise from behind the dash like running water? Quote Link to comment Share on other sites More sharing options...
paul mac Posted January 27, 2009 Share Posted January 27, 2009 i have had the coolant out of my car numerous times for different jobs, the supra is not a car that suffers from air locks and is probably the most straight forward car i have ever had for refilling the coolant system Quote Link to comment Share on other sites More sharing options...
megawatts Posted February 9, 2009 Share Posted February 9, 2009 Eh NO, the one thing it does get IS airlocks. You need to get the front end up well at a good angle, up a ramp, or good incline, take rad cap off, squeeze the lower hoses, and run the engine to bubble off airlocks. See else where Quote Link to comment Share on other sites More sharing options...
paul mac Posted February 9, 2009 Share Posted February 9, 2009 Eh NO, the one thing it does get IS airlocks. You need to get the front end up well at a good angle, up a ramp, or good incline, up on ramps , s'funny i've never read that in the Toyota manual, guess my cars unique, coolant goes in the rad cap, engine starts, top up as necesary, job done Quote Link to comment Share on other sites More sharing options...
gsportcars Posted February 9, 2009 Share Posted February 9, 2009 Hot and cold readings from the gauge seems like air in the system. What kind of noise and please explain what you mean about the blowers.... Have you checked the level in the rad cap while the engine is warming? Make sure your resovior bottle also has enough fluid. Quote Link to comment Share on other sites More sharing options...
