jacko Posted April 24, 2009 Author Share Posted April 24, 2009 ok cheers Quote Link to comment Share on other sites More sharing options...
jacko Posted May 4, 2009 Author Share Posted May 4, 2009 Well today and yesterday i have had both turbos working, which is a nice change, but then probably tommorrow they wont be working again. They seem to go thru phases of both working and then just one for a bit, and then both again. Does that help narrow it down? Im going to take it to the garage soon, but first it's insurance this month....... Quote Link to comment Share on other sites More sharing options...
Scott Posted May 4, 2009 Share Posted May 4, 2009 IACV VSV at a guess. Quote Link to comment Share on other sites More sharing options...
Ian C Posted May 4, 2009 Share Posted May 4, 2009 If it's boosting normally on #1 then dumps all boost at 4000rpm then it'll probably be your EGCV, the one that opens to let exhaust gas through turbo 2. An intermittent issue like this might be a VSV problem. The VSV for that is located on a bracket slung off the bottom of the first turbo, along with the wastegate VSV. Tricky but not impossible to replace without taking half the contents of the engine bay out. -Ian Quote Link to comment Share on other sites More sharing options...
jacko Posted May 4, 2009 Author Share Posted May 4, 2009 Just been for a drive and tried to pay attention to every little thing. Im getting around 3-4psi on the "2nd turbo", and can just hear what sounds like air gushing out of somewhere. Another thing ive noticed is that when the second turbo is working, but not actually online the car chatters a little bit, say sitting at 30 in 4th and then let off, but when it isnt working it doesnt do that, i just get a sort of short sharp dump noise. Im sure this will mean something to somebody, but my knowledge of the sequential system is pretty limited Quote Link to comment Share on other sites More sharing options...
Scott Posted May 4, 2009 Share Posted May 4, 2009 Could be a faulty BOV Quote Link to comment Share on other sites More sharing options...
jacko Posted May 4, 2009 Author Share Posted May 4, 2009 well ive replaced the standard BOV with my Greddy one, unless its something to do with the vac line to the bov... Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted May 4, 2009 Share Posted May 4, 2009 I had similar problems mate, worked through all the guides, eventually came down to my egcv actuator sticking. I replaced this and didn't have a worry afterwards. Have you had a look on max-boost that's probably the best guide I had. Hope it all works out for you bud Quote Link to comment Share on other sites More sharing options...
Steve Posted May 5, 2009 Share Posted May 5, 2009 maomaochong said: Load of tosh Please dont post your crap on here Quote Link to comment Share on other sites More sharing options...
jacko Posted May 16, 2009 Author Share Posted May 16, 2009 Just to let you know i tried the 5min TTC mod today and everything worked fine, so one of the vsv's is obviously slightly temperamental. Just need to find out if it's IACV or EGCV VSV now Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted May 17, 2009 Share Posted May 17, 2009 Hi, i've recently bought a Twin Turbo Aero Top Supra, It now has 65 Injectors, Envy Hybrid Turbos, HSK 264 Cams & Pulleys, Front Mounted Intercooler, Walbrw Fuel Pump and full HKS De-Cat Exhuast, When i got the car they had turned the boost right down to run the turbo's in... What would anyone recommend turning the boost up to? I heard the Turob's will go up to 2.5 Bar but have been told that 1 bar should do it.. Cheers Quote Link to comment Share on other sites More sharing options...
jacko Posted May 17, 2009 Author Share Posted May 17, 2009 I should think 1.4 would be about as far as you'd want to go. Or are the envy hybrids rated to 1.6? Quote Link to comment Share on other sites More sharing options...
Guest drlee Posted May 17, 2009 Share Posted May 17, 2009 sorry ian,duly noted.d Quote Link to comment Share on other sites More sharing options...
Jake Posted May 17, 2009 Share Posted May 17, 2009 DuaneT.Turbo said: Hi, i've recently bought a Twin Turbo Aero Top Supra, It now has 65 Injectors Mines only got 6 Quote I heard the Turob's will go up to 2.5 Bar They might well do - but only once. Quote Link to comment Share on other sites More sharing options...
Steve Posted May 17, 2009 Share Posted May 17, 2009 Would love to see the fuel rail with 65 injectors in, must be a little tight Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted May 17, 2009 Share Posted May 17, 2009 Yeah i was thinkin 1.5bar max! Cheers Quote Link to comment Share on other sites More sharing options...
Steve Posted May 17, 2009 Share Posted May 17, 2009 DuaneT.Turbo said: Yeah i was thinkin 1.5bar max! Cheers Have you got a AFR gauge fitted? If not, you may want to get one before increasing the boost too much to make sure it isn't going lean. Quote Link to comment Share on other sites More sharing options...
jacko Posted May 18, 2009 Author Share Posted May 18, 2009 Does anybody have the part number for the EGCV VSV, i have been searching for a while and found a variety of different numbers for VSV's, so just want to make sure i get the right one!! Cheers Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted May 18, 2009 Share Posted May 18, 2009 Yeah, but i think im gonna get it setup on a rolling road ad dyno'd at same time, know of any places near Derby tha it descent? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted May 18, 2009 Share Posted May 18, 2009 see if you can see it on here jacko. http://www.toyodiy.com/parts/g_J_1995_TOYOTA_SUPRA_JZA80-ALFZZ.html Quote Link to comment Share on other sites More sharing options...
jacko Posted May 21, 2009 Author Share Posted May 21, 2009 Ye cheers, i had a look on my epc disk but gave up after a while lol Ive put the car back into sequential mode now, after the 1.3 bar boost spike last night!! So far both turbos have been working, so fingers crossed it may have just been a knackered vac hose Quote Link to comment Share on other sites More sharing options...
