jawan Posted January 23, 2009 Share Posted January 23, 2009 Hi, I refurbed master cylinder, but when trying to bleed there is no pressure, can't get the fluid to move , any ideas. is it too much air in the system causing this or air has gone in abs systems. Will appreciat quick response.thanks Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 23, 2009 Share Posted January 23, 2009 Are you sure you refitted all the seals O rings the correct way, and lubricated it all with brake fluid on assembly, always pays to prime with a little fluid before refitting. Quote Link to comment Share on other sites More sharing options...
jawan Posted January 23, 2009 Author Share Posted January 23, 2009 sorry whats o ring, i presume thats the lock ring. I fitted the small bolt first then the two half of kit and then end locked it with a metal ring. I am not getting any pressure at all. Before doing this brakes (uk) were slightly spongy but did work. I tried to bench bleed MC . Quote Link to comment Share on other sites More sharing options...
jawan Posted January 23, 2009 Author Share Posted January 23, 2009 Can someone tell which way this goes in Master cylinder. This is the first part of kit that goes in followd by another thanks Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 23, 2009 Share Posted January 23, 2009 Sorry no O ring on the Supra kit, sounds like you may have damaged one of the seals when you installed, when you tested it did you pour some fluid into the reservoir/or both feeds, if it was removed? and did it pump OK from both outlets? Quote Link to comment Share on other sites More sharing options...
jawan Posted January 23, 2009 Author Share Posted January 23, 2009 Any idea how on the pic attache which way this goes in? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 23, 2009 Share Posted January 23, 2009 Here is the manual page, not at all sure if its the same for J spec and UK, hope it helps. Quote Link to comment Share on other sites More sharing options...
