Guest RED GZ Posted March 26, 2005 Share Posted March 26, 2005 I have recently fitted a set of alloys that I bought off ebay last year. They were previously fitted to an import supra with the smaller import brake calipers.Upon fitting them over my english spec calipers the valve caught ever so slightly. Having fitted wheel spacers and subsequently had the wheel balancing checked three times, I still have a wobble on the steering from 50mph upwards. What I'd really like to know having read various threads in technical is whether it is possible at all to completely stop the wobble with wheel spacers on the vehicle, and I also read the phrase "hub centric" spacers, are these what I'm after ? Quote Link to comment Share on other sites More sharing options...
s crane Posted March 26, 2005 Share Posted March 26, 2005 I Have Got Spacers With No Wobble Quote Link to comment Share on other sites More sharing options...
Guest RED GZ Posted March 26, 2005 Share Posted March 26, 2005 what sort of spacers are they ? Quote Link to comment Share on other sites More sharing options...
Robert Posted March 26, 2005 Share Posted March 26, 2005 what size spacers are you using RED GZ? Quote Link to comment Share on other sites More sharing options...
Guest RED GZ Posted March 26, 2005 Share Posted March 26, 2005 They are two 3mm spacers on each side Quote Link to comment Share on other sites More sharing options...
Robert Posted March 26, 2005 Share Posted March 26, 2005 Not sure what to suggest but just check the wheel nuts and bolt to make sure none of the thread has come off, i wouldnt be comfortable to have my wheels wobble at any speed. let me know if u find out whats wrong Quote Link to comment Share on other sites More sharing options...
merckx Posted March 26, 2005 Share Posted March 26, 2005 If you take off a wheel and look at the inside then the hole would be bigger than the diameter of the hub on the car. You need to get a snug fit to keep the wheel centred on the car. You achieve this by fitting a "hub centric ring" made from plastic or aluminium, it should be a snug fit in the wheel then when you fit the wheel to the car it will also hold it centered snuggly on the hub. http://img86.exs.cx/img86/6140/hubcentricring2nc3mj.png Quote Link to comment Share on other sites More sharing options...
s crane Posted March 26, 2005 Share Posted March 26, 2005 I Have Got 5mm Each Side On Front From Autopart Wickford 01268560126 Quote Link to comment Share on other sites More sharing options...
