DodgyRog Posted January 25, 2009 Author Share Posted January 25, 2009 You reach down with some tip-ex and draw a line all the way from the inside to the outside. If they separate,(after a drive or if really bad a few engine revs) as mine have in first post, your crank pulley is shagged:( Link to comment Share on other sites More sharing options...
broomie Posted January 25, 2009 Share Posted January 25, 2009 You reach down with some tip-ex and draw a line all the way from the inside to the outside. If they separate,(after a drive or if really bad a few engine revs) as mine have in first post, your crank pulley is shagged:( cheers Link to comment Share on other sites More sharing options...
supraGZaerotop Posted January 25, 2009 Share Posted January 25, 2009 is this a common thing then, mines done 83000miles now, is it a service item? think il change it to be on safe side Link to comment Share on other sites More sharing options...
dangerous brain Posted January 25, 2009 Share Posted January 25, 2009 Its an age thing I'd say. Rubber perishes with time and heat. About ten years is most rubber's longevity so don't be hugely surprised if you need a replacement on an M,N,P reg. It probably is a service item but who is still getting toyota to service their cars to the schedule after 10 years?? Link to comment Share on other sites More sharing options...
GazzaGSi Posted January 26, 2009 Share Posted January 26, 2009 Wish I'd of known about the tipex test when I had mine. I got through 2. (serves me right to buy one in the for sale section). First time pulling out on a slip road from some services. Second time on the motorway. As said, virtually no to super heavy steering at speed could of been fatal. Its cost me more than a new pulley on both occasions. First time a new rad and second time a smoothed down and resprayed passenger side door. Some how its bounced out and spun up the side of the car with a scratch about a mm deep. Not happy. Glad you spotted yours before anything bad could of happened! Link to comment Share on other sites More sharing options...
DodgyRog Posted January 27, 2009 Author Share Posted January 27, 2009 Wish I'd of known about the tipex test when I had mine. I got through 2. (serves me right to buy one in the for sale section). First time pulling out on a slip road from some services. Second time on the motorway. As said, virtually no to super heavy steering at speed could of been fatal. Its cost me more than a new pulley on both occasions. First time a new rad and second time a smoothed down and resprayed passenger side door. Some how its bounced out and spun up the side of the car with a scratch about a mm deep. Not happy. Glad you spotted yours before anything bad could of happened! I only found through reading a load of threads about squeaky/squealy noises that might be belt related but didn't go away after replacing the belt Link to comment Share on other sites More sharing options...
den1 Posted January 27, 2009 Share Posted January 27, 2009 Standing in front of the car..looking down at the crank pulley. The centre bolt that holds the pulley onto the crankshaft...To remove the bolt does it turn anticlockwise or clockwise ( Left Handed Thread) Thanks Link to comment Share on other sites More sharing options...
DodgyRog Posted January 27, 2009 Author Share Posted January 27, 2009 Standing in front of the car..looking down at the crank pulley. The centre bolt that holds the pulley onto the crankshaft...To remove the bolt does it turn anticlockwise or clockwise ( Left Handed Thread) Thanks From what I remember reading, it is normal thread, so anti clockwise to undo. They are usually ridiculously tight Link to comment Share on other sites More sharing options...
den1 Posted January 27, 2009 Share Posted January 27, 2009 Standing in front of the car..looking down at the crank pulley. The centre bolt that holds the pulley onto the crankshaft...To remove the bolt does it turn anticlockwise or clockwise ( Left Handed Thread) Thanks Something else to consider doing the near future (summer) Link to comment Share on other sites More sharing options...
DodgyRog Posted January 27, 2009 Author Share Posted January 27, 2009 Mines booked in for Saturday, decided not to attempt it myself. I need it back running asap and can't afford to run the risk of me not being able to do it and putting back the repair any further. Paul Whiffin has said he won't have any stock until Thursday (at the earliest), so wouldn't of been able to get it to me by Saturday. So I had to cough up to Mr.T £236 inc VAT for the crank pulley and a new bolt just incase. Been told to expect 1 1/2 hour labour bill, which my local mechanic charges £60 an hour. So hopefully back running for around £325 Link to comment Share on other sites More sharing options...
den1 Posted January 27, 2009 Share Posted January 27, 2009 How much is Paul Whiffin charging for the crank pulley:) Link to comment Share on other sites More sharing options...
DodgyRog Posted January 27, 2009 Author Share Posted January 27, 2009 How much is Paul Whiffin charging for the crank pulley:) About £180 delivered, he has 2 coming in from Japan, but 1 is already sold, so be quick if you want it;) Link to comment Share on other sites More sharing options...
GoliathJay Posted January 27, 2009 Share Posted January 27, 2009 anyone point out where the pulley is so i can apply the tipex test? Link to comment Share on other sites More sharing options...
den1 Posted January 27, 2009 Share Posted January 27, 2009 There's more about it on this thread http://www.mkivsupra.net/vbb/showthread.php?t=35945 This includes a photo of the bottom pulley ( Although not a standard one!) Link to comment Share on other sites More sharing options...
dangerous brain Posted January 27, 2009 Share Posted January 27, 2009 So sorting mine for £100 was a proper bargain then Link to comment Share on other sites More sharing options...
matt k Posted January 27, 2009 Share Posted January 27, 2009 So sorting mine for £100 was a proper bargain then Depends what brand it is. Link to comment Share on other sites More sharing options...
dangerous brain Posted January 27, 2009 Share Posted January 27, 2009 Toyota genuine parts and DIY Link to comment Share on other sites More sharing options...
