supra matt Posted January 21, 2009 Share Posted January 21, 2009 looking at the numbers on it looks like was made 21 week 2005? Link to comment Share on other sites More sharing options...
merckx Posted January 21, 2009 Share Posted January 21, 2009 (edited) looking at the numbers on it looks like was made 21 week 2005? I'm not sure, i've just had a look at my Goodyear's and the number isn't in the same format as Wez's. I've got... DOT NE4N 2JJR 2506 , in my case 25 week 2006. On the link that was posted about tyre age it looks like "DOT" proceeds the number. I might be wrong though Edited January 21, 2009 by merckx (see edit history) Link to comment Share on other sites More sharing options...
TTRickeh Posted January 21, 2009 Share Posted January 21, 2009 Maybe the Eagle F1's have this number posted on the right hand side of them? Did you check passenger or drivers side merckx? I had to check my drivers side as I couldn't find it facing me on the passengers side. Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2009 Author Share Posted January 21, 2009 I've got... DOT NE4N 2JJR 2506 , in my case 25 week 2006. Just checked mine and I have a similar pattern on the other side, mine ends 4707, looks like mine are newer than yours Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted January 21, 2009 Share Posted January 21, 2009 Look's like the tyre has been run flat at some stage, causing the side wall to delaminate (internal) and blow. Have you checked inside the tyre for anything that may have caused this? Link to comment Share on other sites More sharing options...
Wez Posted January 21, 2009 Author Share Posted January 21, 2009 Not yet, will have a proper look at it over the weekend. The tires were purchased in Jan 2008, I found the receipt, I dont ever recall them going flat, its highly possible that it got a puncture on the way and then went pop when it dropped in psi. I checked the other rear and it is 34psi as it should be, the fronts are 35psi and 36psi Link to comment Share on other sites More sharing options...
merckx Posted January 21, 2009 Share Posted January 21, 2009 (edited) Did you check passenger or drivers side merckx? I had to check my drivers side as I couldn't find it facing me on the passengers side. I checked the drivers side. Just checked mine and I have a similar pattern on the other side, mine ends 4707, looks like mine are newer than yours I don't drive the car enough, there's still loads of tread on them too. Edited January 21, 2009 by merckx (see edit history) Link to comment Share on other sites More sharing options...
