Had a small puncture today
Wez
looking at the numbers on it looks like was made 21 week 2005?
I'm not sure, i've just had a look at my Goodyear's and the number isn't in the same format as Wez's. :)
I've got... DOT NE4N 2JJR 2506 , in my case 25 week 2006.
On the link that was posted about tyre age it looks like "DOT" proceeds the number.
I might be wrong though :)
Edited by merckx (see edit history)
Not yet, will have a proper look at it over the weekend.
The tires were purchased in Jan 2008, I found the receipt, I dont ever recall them going flat, its highly possible that it got a puncture on the way and then went pop when it dropped in psi.
I checked the other rear and it is 34psi as it should be, the fronts are 35psi and 36psi :search:
Did you check passenger or drivers side merckx? I had to check my drivers side as I couldn't find it facing me on the passengers side.
I checked the drivers side. :)
Just checked mine and I have a similar pattern on the other side, mine ends 4707, looks like mine are newer than yours :D
:( I don't drive the car enough, there's still loads of tread on them too. :)
