DodgyRog Posted January 20, 2009 Share Posted January 20, 2009 I have spent last couple of hours going through various thread's and found different sizes/codes. Can someone just confirm which one is correct for a 1995 N/A manual. I think both codes are for Gates auxiliary belts 6PK1940 6PK1938 My last belt is a gates and is coded 68441, which is apparently a wrong belt. The other thing I want to check, is I have seen a couple of mentions of markers/goal posts, at the top of the tensioner. Can someone explain how the markings should line up. I have got a quiet squeak (annoying as hell), so am going to change the belt, I have checked the crank pulley and it seems okay (fingers crossed), so I think the belt might be to long so the tensioner is strugling to keep tension. I have WDed the spin points of all the pulleys and checked they all turn freely. Cheers in advance, will check back on and off while watching footie;) Link to comment Share on other sites More sharing options...
Scooter Posted January 20, 2009 Share Posted January 20, 2009 This link should help (there is a further link in this one too) Link to comment Share on other sites More sharing options...
DodgyRog Posted January 20, 2009 Author Share Posted January 20, 2009 This link should help (there is a further link in this one too) Thanks Scooter, that's the one I saw and couldn't find again about the markers. So that's that bit answered, any idea on belt size ? Link to comment Share on other sites More sharing options...
DodgyRog Posted January 20, 2009 Author Share Posted January 20, 2009 My marker is all the way over to the right, which would explain why it is sliping, even thou their is know sign of wear:rolleyes: Link to comment Share on other sites More sharing options...
Scooter Posted January 20, 2009 Share Posted January 20, 2009 I think the belt no's you listed are sort of a code where the 6 before the PK means it has 6 ridges (or it may be 6 grooves) and the 4 digits after are the total belt length in MM which would make the choice between the two insignificant. Link to comment Share on other sites More sharing options...
Scooter Posted January 20, 2009 Share Posted January 20, 2009 http://www.gates.com/part_locator/index.cfm?location_id=3598 it didn't save my 'Supra' selection in this link but fill it in and the current gates item has a 1937mm length. Link to comment Share on other sites More sharing options...
DodgyRog Posted January 20, 2009 Author Share Posted January 20, 2009 Many thanks Scooter, your help is much appreciated:cool: For future reference, a link to the correct Gates search site (Europe) and if you click on the camera (when you find the belt) it shows how to but the belt back on for those that may need it. https://www.gates-online.com/GatesEU/en/GB/adirect/gateu1?cmd=Automotivewebcat Link to comment Share on other sites More sharing options...
Batmax Posted January 31, 2009 Share Posted January 31, 2009 where i can buy it ? Link to comment Share on other sites More sharing options...
Batmax Posted January 31, 2009 Share Posted January 31, 2009 I find these, could these price be correct : http://www.mister-auto.com/gates-courroie-trapezoidale-a-nervures,6PK1938,033,a305.html Link to comment Share on other sites More sharing options...
DodgyRog Posted January 31, 2009 Author Share Posted January 31, 2009 I find these, could these price be correct : http://www.mister-auto.com/gates-courroie-trapezoidale-a-nervures,6PK1938,033,a305.html Its the right belt code, so guess the price is right;) I paid just under £15 from my local garage. Any decent motor factors should be able to get this for you:D Link to comment Share on other sites More sharing options...
trebor69 Posted August 30, 2013 Share Posted August 30, 2013 Can anybody tell me if the TT and N/A auxilliary belts are the same size please ? .....from what I can gather its a 6PK1936 for the TT whereas above Rog has 6PK1940 and 6PK1938 figures ......can't find anything on the N/A Thanks. Link to comment Share on other sites More sharing options...
DodgyRog Posted August 31, 2013 Author Share Posted August 31, 2013 Can anybody tell me if the TT and N/A auxilliary belts are the same size please ? .....from what I can gather its a 6PK1936 for the TT whereas above Rog has 6PK1940 and 6PK1938 figures ......can't find anything on the N/A Thanks. The belts for TT and N/A are the same code, code should be 6PK1938 from memory I have done an Aircon delete now so I can't check unfortunately Link to comment Share on other sites More sharing options...
trebor69 Posted August 31, 2013 Share Posted August 31, 2013 The belts for TT and N/A are the same code, code should be 6PK1938 from memory I have done an Aircon delete now so I can't check unfortunately No problem dude, thanks. Link to comment Share on other sites More sharing options...
