Auxiliary belt size/codes
DodgyRog
I have spent last couple of hours going through various thread's and found different sizes/codes.
Can someone just confirm which one is correct for a 1995 N/A manual.
I think both codes are for Gates auxiliary belts
6PK1940
6PK1938
My last belt is a gates and is coded 68441, which is apparently a wrong belt.
The other thing I want to check, is I have seen a couple of mentions of markers/goal posts, at the top of the tensioner.
Can someone explain how the markings should line up.
I have got a quiet squeak (annoying as hell), so am going to change the belt, I have checked the crank pulley and it seems okay (fingers crossed), so I think the belt might be to long so the tensioner is strugling to keep tension.
I have WDed the spin points of all the pulleys and checked they all turn freely.
Cheers in advance, will check back on and off while watching footie;)
  • 2 weeks later...
  • 4 years later...
Can anybody tell me if the TT and N/A auxilliary belts are the same size please ? .....from what I can gather its a 6PK1936 for the TT whereas above Rog has 6PK1940 and 6PK1938 figures ......can't find anything on the N/A :(
Thanks.
The belts for TT and N/A are the same code, code should be 6PK1938 from memory
I have done an Aircon delete now so I can't check unfortunately
