Chiefgroover Posted January 20, 2009 Share Posted January 20, 2009 Anyone here built an engine with their black F1 bearings? Any reports of expereince of them would be appreciated. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 20, 2009 Share Posted January 20, 2009 Are those the ones that aren't made in the full range of sizes? How does that work? (I might be thinking of some other ones, it's late) Quote Link to comment Share on other sites More sharing options...
SimonB Posted January 20, 2009 Share Posted January 20, 2009 Are those the ones that aren't made in the full range of sizes? How does that work? (I might be thinking of some other ones, it's late) Nah, they are the ones that ARE made in the full range of sizes. I was going to use them for that reason but they were just too expensive. As it happened the variation in sizes between the ones I needed were so small that standard size bearings produced tolerances that were all in range. So I used ACL in the end. You will probably find the same if you need bearings in the 2-5 sort of size range. Quote Link to comment Share on other sites More sharing options...
TLicense Posted January 20, 2009 Share Posted January 20, 2009 The problem I found with Power Enterprise bearings is that they're a real pain in the a*se to get ahold of. The only person who I found capable of getting them was Nick, but even then they took a while to arrive. Actually I think dusty could get them but the delivery was almost as much as the bearings themselves. In the end when they did arrive I found I'd mis-ordered one main bearing. Rather than wait around for another age, I just went sacked them all off and went with Toyota bearings. Quote Link to comment Share on other sites More sharing options...
