Final Garage Clearout
Luka-P
Hi Guys,
I've been clearing out the last of my stuff. I came across some bits I thought might be of use to someone. Storage is limited at my new place so I'll have to shift this lot. I've taken a few pictures. Stuff for sale is listed at the top. Free stuff is underneath, just needs P+P paying for! The list is as follows:
1. 90 Degree elbow with HKS SSQV BOV. Flange has been welded on - £80
2. Supra mats in black with grey trim. Front and rear. Not been used - £40
3. Stereo dash panel. Very good condition - £20
4. First and second undertray with screws - £25 each
5. HID kit. Still have the box - £50
6. Engine stand. Ideally I would like to keep this but I'm pushed for space. If anyone would like it it's theirs for £40. Come with correct fine pitch bolts which go into the Supra engine.
7. Piston ring compressor and valve spring compressor. Again, I wouldn't mind keeping these but if anyone is interested in them in the meantime. PRC - £10. VSC - £30, modified to fit Supra head. I also have a piston ring expander. £5.
8. Oil squirters for the TT bores. 6 of them with bolts. £5
9. JSpec turbo pipework. The EGCV and Y piece which connects the two turbos. £5 each.
10. Master cylinder. It has no cap though. £15
11. Warning light display. The one on the right of the eyebrow piece. £5
12.Various hoses. 3mm vac hose. 1/4, 5/16 and 19mm. ~1m of each.
£2 each.
13. Aftermarket wheel nuts. 20 including locking nuts. £10.
FREE STUFF! JUST P+P!
14. Main caps. Standard for the TT block. Before they go in the bin.
15.Crank pulley. From Keron, low mileage engine.
16. Gold Toyota badge.
17. Grab handle. I think one of the clips are broken but the handle is there.
18. Turbo vac controls. Not sure which, from the bottom of tubbie 1.
19. Pioneer front speakers fitted into stock modified housings. Bolt straight in, direct replacement.
20. Turbo heat shield.
21. Spare rad clamp.
All items plus postage and packaging on top. Payment via Bank Transfer (preferred) or PayPal. Collection is welcome from the Derby area. PMs preferred. I'll list more as I find it.
Cheers,
Luke
Morning, morning.
By first undertray, do you mean the big one under the engine? Because I need one of them badgers. Postage?
Fancied the mats, too, but I guess they've gone. Where did you get them from?
I know you said PMs preferred, but that's several extra clicks :)
Cheers!
  • 2 weeks later...
