Sticking Clutch Pedal
Guest janjim
Hi all,
Can you help please, my son has a problem with his Mk 1V Supra in that the clutch pedal will not return to its 'release' position.
I have had a quick look but am unable to identify where the problem may be. The car is a 1995 model. Any idea's please.
Many thanks, janjim.
well i have changed my own clutch twise and to be honest can only think of 2 reasons why this would happen, 1 the release bearing that slide's up and down the output shaft of the gearbox is getting jamed or the clutch its self has stuck together.
If the pedal is down all the time will the car not drive.
The other thing is it might be out of fluid.
had the same problem,
got an overhaul kit for the clutch cilinder,
not the one on the tranny but behind the paddles,
or is that the slave cilinder..
in holland we call it giver and taker,
taker is the one on the tranny,
how do you guys call both?
Just a shameless plug here - if it will be slave clutch cylinder - I have oone brand new for sale :) I could even put it on the car for small fee, but I suppose you are quite far away from Wolverhmampton :p
:stickpoke Unrequested pimping of stuff to sell in tech is frowned upon. Don't do it again :)
-Ian
Guest suprapaul1980
i had exactly the same problem so i changed the gutts on the clutch master cylinder wich cost approx £40 from toyota for the master cylinder repair kit and it solved the problem
