VFCC Wiring diagram
penguin
hey guys, got the decat done :respekt: ... but the exhaust isnt standard one (it says jasma on it tho :rtfm: ) and its not as loud as it used to be :swear: .... but, i tried to wire up the vfcc (fuel cut defender) on my soop, and the wiring diagram supplied is totally diffrent :eek: ... i mean, my soops pinouts are totally diffrent (yes i did look to see if it was the right one.... Non vvti supra twinturbo) ... help :tumble: :violin:
thanks dude, but thats the diagram i got with it, but all my pin numbers are totally diffrent, and the power/map wire are not actually at those connections :swear:
Unless you've got a stand alone/aftermarket ECU and had the loom re-wired to suit, I can't see how your pin numbers can be different, let alone the power MAP sensor wire being not being at those locations.
The JDM TT wiring looms are all the same, unless you have a VVTi. (97 onwards)
I'd re-check if I were you ;)
How do you mean your 'pin numbers are different'? And where are your Power/MAP wires it they aren't in the same place as every other PreFacelift JSpec?
A picture and/or more info would help us to help you.
