Animal Posted January 18, 2009 Share Posted January 18, 2009 I had the door cards off yesterday to fix the passenger side window and the drivers side central locking (Both easy fixes). On the drivers' side, in the same bit of loom as the central locking connector block, there were 2 black wires corroded to buggery that look like they should be attached to a microswitch on the outer door skin. Now, my central locking works fine and we didn't fancy stripping the door down any further, so we just left 'em. Any ideas what they are? I'm wondering if it is part of an old alarm system or something. Cheers. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted January 18, 2009 Share Posted January 18, 2009 I had the door cards off yesterday to fix the passenger side window and the drivers side central locking (Both easy fixes). On the drivers' side, in the same bit of loom as the central locking connector block, there were 2 black wires corroded to buggery that look like they should be attached to a microswitch on the outer door skin. Now, my central locking works fine and we didn't fancy stripping the door down any further, so we just left 'em. Any ideas what they are? I'm wondering if it is part of an old alarm system or something. Cheers. yes it goes to a small micro switch on drivers lock Quote Link to comment Share on other sites More sharing options...
Animal Posted January 18, 2009 Author Share Posted January 18, 2009 Cool, cheers. All the locks worked, and my alarm works, so I figured we could ignore it. Quote Link to comment Share on other sites More sharing options...
bakerk Posted February 10, 2010 Share Posted February 10, 2010 yes it goes to a small micro switch on drivers lock Matt ....is that the microswitch that pushes onto the back of the door lock barrel? If so is it cool just to disconnect it on the white multiway half way down the door.. Having a real job getting a replacement and It seems to be stopping the central locking from working in it's current state cheers:rolleyes: Quote Link to comment Share on other sites More sharing options...
