scotty supra Posted January 18, 2009 Share Posted January 18, 2009 (edited) aa Edited August 13, 2009 by scotty supra (see edit history) Link to comment Share on other sites More sharing options...
SteveR Posted January 18, 2009 Share Posted January 18, 2009 You have to cook them Have a search for "headlight refurb" edit http://www.mkiv.com/techarticles/headlights/index.html Link to comment Share on other sites More sharing options...
dr_jekyll Posted January 18, 2009 Share Posted January 18, 2009 thats what i did , be sure not to let any part of the light be in contact with the side of the oven though , it will melt , but other than that worked well Link to comment Share on other sites More sharing options...
gavin.starr Posted January 18, 2009 Share Posted January 18, 2009 i used a hair dryer took a bit longer but it did the trick Link to comment Share on other sites More sharing options...
gordy07 Posted January 18, 2009 Share Posted January 18, 2009 hammer? Link to comment Share on other sites More sharing options...
adnanshah247 Posted January 18, 2009 Share Posted January 18, 2009 hammer? & chisel Link to comment Share on other sites More sharing options...
Blackie Posted January 18, 2009 Share Posted January 18, 2009 i used a hair dryer took a bit longer but it did the trick Sod that, I tryed to do mine with a hairdryer and its impossible to heat it all up to prize it apart. Used the oven effort in the end and they pulled apart no problem Link to comment Share on other sites More sharing options...
scotty supra Posted January 18, 2009 Author Share Posted January 18, 2009 (edited) aa Edited August 13, 2009 by scotty supra (see edit history) Link to comment Share on other sites More sharing options...
gordy07 Posted January 18, 2009 Share Posted January 18, 2009 Your welcome mate Link to comment Share on other sites More sharing options...
gavin.starr Posted February 19, 2009 Share Posted February 19, 2009 my oven aint big enough Link to comment Share on other sites More sharing options...
DAT Inter Posted February 19, 2009 Share Posted February 19, 2009 Electric oven, fan assisted 170 oC. In the oven for 3 mins 30. and out immediately then pull apart. Be carefull with the fog lamp bit. It melts easily. Link to comment Share on other sites More sharing options...
suprattgaz Posted February 19, 2009 Share Posted February 19, 2009 Hot air gun. My oven is gas so don't trust it. Must have done 8-10 like it now. Start from the inner most bottom corner (as if sat on car) and slowly heat and prise from there. I can do it in 5 mins now, less than what it takes if you put it in the oven Link to comment Share on other sites More sharing options...
Scott Posted February 19, 2009 Share Posted February 19, 2009 Bit toasty i reckon. I did mine at 80 degrees C for 10 mins and the prized apart easily. I wouldn't fancy my chances with 170 lol. Link to comment Share on other sites More sharing options...
JamesG Posted February 19, 2009 Share Posted February 19, 2009 170 degrees Fahrenheit. Link to comment Share on other sites More sharing options...
black_widow87 Posted January 5, 2012 Share Posted January 5, 2012 Might seem abit of a daft question but i just want to check before i destroy my headlight. Is this where the lense apparantly splits?? Seems very well stuck together if it is! Link to comment Share on other sites More sharing options...
mellonman Posted January 5, 2012 Share Posted January 5, 2012 Might seem abit of a daft question but i just want to check before i destroy my headlight. Is this where the lense apparantly splits?? Seems very well stuck together if it is! no not there its the back part where it goes into the clear front. Link to comment Share on other sites More sharing options...
black_widow87 Posted January 5, 2012 Share Posted January 5, 2012 You mean here? The crease line where i removed the small metal clips? Link to comment Share on other sites More sharing options...
mellonman Posted January 5, 2012 Share Posted January 5, 2012 You mean here? The crease line where i removed the small metal clips? yep the clips help hold it in place iirc, for every one putting in the electric oven dont set it to grill and keep a eye on it, you can over cook them Link to comment Share on other sites More sharing options...
edd_t Posted January 5, 2012 Share Posted January 5, 2012 i over cooked mine made the oven smell and melted all the black parts of the lights, lense was ok though Link to comment Share on other sites More sharing options...
black_widow87 Posted January 5, 2012 Share Posted January 5, 2012 Iv been using the hairdryer for the last 20mins and the bleedin' thing wont come apart! Is there some kind of technique when doing it this way? Link to comment Share on other sites More sharing options...
Purity14 Posted January 5, 2012 Share Posted January 5, 2012 Iv been using the hairdryer for the last 20mins and the bleedin' thing wont come apart! Is there some kind of technique when doing it this way? Yeah, you need a heat gun Link to comment Share on other sites More sharing options...
d-_-b Posted January 5, 2012 Share Posted January 5, 2012 (edited) Iv been using the hairdryer for the last 20mins and the bleedin' thing wont come apart! Is there some kind of technique when doing it this way? Can be done with hairdryer - have done it on about 6 different light units, you have to make sure the hairdryer is on "hot" not the luke warm heat, and try and heat from the back (you will see like a lip the whole way around on the black part of the housing - this is where the adhesive is) you will need to concentrate on a smaller area and move along bit by bit parting the bit you just done after it has become soft enough to start seperating. *Dont just stay on the same point for ages as this could damage the housing or worse the lens, move up and down across say a 6" stretch, then start pulling apart that section, then move around. You will never do the whole lens in one go using the hairdryer. (it takes usually at least 2 oven sittings to remove the lens and thats with the "overall" heating oven) The oven method is easier (have done both the hairdryer and oven "techniques") but granted is more daunting putting your light in an oven . . > Edited January 5, 2012 by d-_-b (see edit history) Link to comment Share on other sites More sharing options...
