empty first cat (1bar)
Rinus
Hi,
I emptied my first original cat.,
I already had fitted 2nd decat,
and hks catback,
greddy-bcc...
walbro
and of course the 1.2bar restrictor ring...
-->boost 0.8bar, thats to low..
Lets try it carefull without the rest-ring,
1,05bar at full boost :blink:
*I think for now the power on 1 bar is fine, and it doesn't
kill my turbo's so quickly...
But is the empty first cat even now a bit restrictive,
cause of the "box" model, compared to a 1st jspec decat??
its a hks power exhaust (4inch I thought)
what I mean is;
if you normally put a full decat exhaust on a j-spec car,
the turboos will spin up to 1.6 bar,
cause of the smaller wastegate than a uk-spec car...
and then the turbo's wil die cause they can handle max 1.2 bar,
then you can put a 1.2 bar restrictor ring in it and it stays niceley
on 1.2 bar
now I did the same on my car, but the only difference is
that I used the original first cat and took al the stuff whats in there out, and whitout the ring I boost 1,05 bar max,
with the ring 0,8 bar...
this means that with an aftermarket 1st decat whitout ring--> 1.6bar
and original empty first cat without ring--> 1,05 bar
I can't believe that this makes a 0.6 bar difference...
