Danno's Supra Build
DannoSupra
  • Replies 193
Coming along very nicely. Removing all your boot build must have been a nightmare. Are you keeping the UK bonnet and rear lights? There won't be much 'UKness' left on the car once the single is fitted :)
Keeping the UK Bonnet, i got Facelift and UK Rear Lights to choose from too, ohhh i still got my UK Headlights and... i think thats it :D
Sound system was made so it could be lifted out very easy, well, it was a bit on the heavy side, its not going back in :rolleyes:
Go on... how heavy was it :D
One thing im worried about is the numberplate mounting, there's nowt except a few mm lip in the numberplate cut out to mount it, suppose if i get one that fits perfect or i cut one down, i could bont it onto that little lip
i had an issue like this on mine as its a j-spec bumper with the bigger hole and i wanted to use the smaller plate with the bike size lettering that you can get away with on a
j-spec :eyebrows: i had very little to fasten to, i soughted it with a piece of 3mm thick ally that was about 50mm longer either side than the hole, i araldited it in from the rear then used the sticky pads you can get for number plates rather than the plastic screws, once the number plate is on it sandwich's it all together even if the araldite should fail, from memory the plate was about 80-100mm wide
