Danno's Supra Build
DannoSupra
  • Replies 193
Bit more work done today
I dusted the body and gave her a polish :cool:
Got a list of interior panels and parts needed
Sorted a bit of the interior wiring, binned the SRS, fitted the clutch pedal and slave, manual brake pedal, refit the heaterbox and dashboard
No piccies really sorry guys, i'll be going back this week somepoint to get some snaps. The lights in the unit is poor for pics, will need daylight!
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
Progress - i spent an hour or two tonight, started building the shortblock :)
JamieP's Forged Block, cleaned up and fitted new headgasket
Whifbitz Stage 4 (inc 1mm oversize valves) head fitted with L19 ARP Studs
New Exhaust Studs
and i couldn't resist a test fit :thumbs: - along with a set of 280 Cams
.... hopefully towards the end of the week i'de have sorted the timing covers, cam and crank pulleys, timing belt, water pump etc
  • 3 months later...
  • 2 weeks later...
  • 3 months later...
  • 2 weeks later...
Cheers chaps :)
Haven't been working on her for the past few months. Been over today to gather my head a list up few bits n bobs I still need
I'm thinking of ABS delete, and use that corner for PAS Tank, FuseBox, Fuel Reg etc. I have to relocate PAS Tank and FuseBox due to inlet anyhow
ABS and Taction has now been removed!
Going to replace with Cupro Nickel and add an Electronic LineLock :) Then need to cut the look back and do some tucking
Two Questions:
Does anyone know what size and thread unions i need so i can get some bought up ready for when i start doing the pipes?
Am i right in thinking Non ABS Supra's have got 3 outlets on the master cylinder?
Thanks in advance :thumbs:
Pics:
image image
