meph137 Posted January 17, 2009 Share Posted January 17, 2009 Hey all, wondered if anyone has a few spare interior trim fixings and other bits such as seatbelt fixing bolts that they could give me? I'm sure I can part with a bit of cash if they are in good nick I've bolded the things I really, really want Things I want: The 10mm hex bolt used to fix the top of the seatbelt on, and the 14mm one used to fix the bottom on if you have it Those weird coathanger things on the top of the rear seat trim, the very small hook things Those white plastic clips used to fix two parts of the bottom rear seat trim panels Normal trim screws Short trim screws (the ones used on the top rear panel) Trim screw covers (the black disc's, both for the plastic trim and the doorcards) The black push rivet things used for some trim areas Any of the fixings used on doorcars, electric windows etc Any things such as above are very welcome, if you cant be arsed to sort through just send me a bag cheers! Link to comment Share on other sites More sharing options...
