What is the stock starter motor current draw?
RobSheffield
Need to place a fuse (yes Brett, in a holder, i know!) in the extended live that runs forward from my relocated battery to the fusebox.
Cheers.
PS, alternatively i may look for a high Amperage circuit breaker type arrangement, believe i have seen that suggested before for the same application.
Edited by RobSheffield (see edit history)
Rob, not sure if this helps, but seach for lightweight battery threads, there was something in one of them about the current draw on the starter motor (CCA - cold cranking amps???? does this sound like what you want to know?)
I'll have a dig.
Edit this thread is on about the stock cranking amperage being under 200A http://www.mkivsupra.net/vbb/showthread.php?t=156790&highlight=lightweight+battery
Also it's on about info in the battery FAQ
Edited by jevansio (see edit history)
