fuel hanger
supraspeed
ok my fuel gauge and speedo stopped working a while back and electrician said it was not the fuses or the clocks/dials
was told it might be the fuel hanger as this was possibly touched when car was being repaired. where is it located as i have no idea- my mate told me it was in the boot under the spare wheel bit and to undo about 6 bolts to get to the fuel tank. i did that and now i'm lost after realising i dont know what a fuel hanger looks like lol. also i dont know why my speedo isn't working, any ideas? (not rubbing/jammed on facia either)
any help or diagrams would be really helpful :)
If the car starts and runs, then the fuel pump (which is held by the fuel hanger) is working.
I'm not an expert, but there is no way I can imagine that the two can be related.
I would check ALL of the fuses before going any further; there are 2 fuse boxes, one in the engine bay and the other just to the right and above your accelerator pedal.
After that I would check the connections to the speedo head (3 large connectors; blue white and brown IIRC) and the odometer.
checked all fuses and all fine- replaced a few this morning for stereo and wipers. the connections are fine behind the clocks but i remember the electrician said something about fuel sender unit might be damaged and also a wire from the gearbox (he didn't bother looking for it) might have something to do with the speedo not working. i'm bit lost with all this technical stuff :(
