Guest bmx Posted January 10, 2009 Share Posted January 10, 2009 i have a noise that sounds like there is something catching on my drivers side front or rear not sure, but it is on and off not all the time. its not the wear indicator as ive got loads left on the pads. also wen you brake it will not make the noise. stripped them down a week ago and its bin fine but now its back any ideas? Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 10, 2009 Share Posted January 10, 2009 i have the same prob when i jacked it up when i spin the wheel on part of every rotation it makes a scrapping noise, like goes round scrape goes round scrape im changing my disks and pads anyway so hope that fixes it Quote Link to comment Share on other sites More sharing options...
dani_r Posted January 10, 2009 Share Posted January 10, 2009 I had that problem! It only made a noise at certain times like when i turned right or something! Turned out to be one of the clips that holds the pads in place had moved or bent and was touching the disk! Pull your wheels and pads off and just look down at the clips to see if any of them make contact with the disc. One of the clips on my drivers side front was making contact so I just pulled the holder off and grinded the metal clip down a few mm until it was clear. It hasn't done it since! Hope that helps Quote Link to comment Share on other sites More sharing options...
Guest bmx Posted January 10, 2009 Share Posted January 10, 2009 thanks mate will have a look monday will be back on then if its sorted or not. Quote Link to comment Share on other sites More sharing options...
Supra-Brett Posted January 10, 2009 Share Posted January 10, 2009 I had that problem! It only made a noise at certain times like when i turned right or something! Turned out to be one of the clips that holds the pads in place had moved or bent and was touching the disk! Pull your wheels and pads off and just look down at the clips to see if any of them make contact with the disc. One of the clips on my drivers side front was making contact so I just pulled the holder off and grinded the metal clip down a few mm until it was clear. It hasn't done it since! Hope that helps I was about to say the same thing, but also could be a seized slider if its J-spec Quote Link to comment Share on other sites More sharing options...
Bossco Posted January 10, 2009 Share Posted January 10, 2009 I had that problem! It only made a noise at certain times like when i turned right or something! Turned out to be one of the clips that holds the pads in place had moved or bent and was touching the disk! Pull your wheels and pads off and just look down at the clips to see if any of them make contact with the disc. One of the clips on my drivers side front was making contact so I just pulled the holder off and grinded the metal clip down a few mm until it was clear. It hasn't done it since! Hope that helps I've also had the exact same problem. Make sure you check all the clips including the ones that go on the other side of the disc. Sometimes you can get away with bending it back rather than grinding it down. That said mine had to be grinded to stop the noise. Quote Link to comment Share on other sites More sharing options...
supradriver Posted January 10, 2009 Share Posted January 10, 2009 DIFF have it looked at. mine made a noise like that befor it went. Quote Link to comment Share on other sites More sharing options...
