uk spec cams v jdm spec cams
Stephen G
No very different to HKS cams.
The UK spec intake cam has slightly longer duration, higher lift compared to the J-spec, the exhaust cams are identical.
J-spec Cam Specs
Intake Cam - 224°, 7.88mm lift
Exhaust Cam - 233°, 8.4mm lift
UK Cam Spec
Intake Cam - 233°, 8.25mm lift
HKS Cam Specs (the shortest duration cams available).
HKS Camshaft - Intake 256°, 8.7mm lift
HKS Camshaft - Exhaust 256°, 8.7mm lift
