JamieP Posted January 9, 2009 Share Posted January 9, 2009 Mine has just started to beep 5 times when i lock the car, any ideas? Cheers:) Quote Link to comment Share on other sites More sharing options...
hadyn Posted January 9, 2009 Share Posted January 9, 2009 low battery? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2009 Author Share Posted January 9, 2009 The car or fob? Quote Link to comment Share on other sites More sharing options...
AlanM Posted January 9, 2009 Share Posted January 9, 2009 Mine, A606i I think, does that on odd occasions, no sort of reasoning to it at all. I usually just unlock it again and re-lock. Once usually, but not always, clears it Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2009 Author Share Posted January 9, 2009 Yup A606i Mine has been doing it for a couple of weeks now, very annoying when i come in late and trying to be quiet. Quote Link to comment Share on other sites More sharing options...
AlanM Posted January 9, 2009 Share Posted January 9, 2009 You got two fobs? Does it do it with both? Both mine do which points away from the fob (battery) Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2009 Author Share Posted January 9, 2009 You got two fobs? Does it do it with both? Both mine do which points away from the fob (battery) Ill have to have a look for the other one, not sure where it is now. Quote Link to comment Share on other sites More sharing options...
DannyB Posted January 9, 2009 Share Posted January 9, 2009 if shes a bit noisey mate lock with the small button underneath the lock button, mine was set to silent arm, maybe yours is too? Just untill you sort the problem. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2009 Author Share Posted January 9, 2009 Ahh right, ill try that. Quote Link to comment Share on other sites More sharing options...
michael Posted January 9, 2009 Share Posted January 9, 2009 Could be the bonnet switch (or one of the others), the Toad ones are pants in my experience, they don't like damp - pop the bonnet, pump the sprung switch up and down a few times and then close up to try again. 5 beeps is the "pre warn" feature I think, tells you something hasn't shut properly, can be set to 2 beeps too though - usually ends with the alarm going off though so maybe I'm talking crap again. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 9, 2009 Author Share Posted January 9, 2009 Ok ill give that a try, ta. Quote Link to comment Share on other sites More sharing options...
fizzle Posted January 9, 2009 Share Posted January 9, 2009 yeah mine does 5 beeps if doors, boot or bonnet not closed properly! give em all a slam and should be sweet! Quote Link to comment Share on other sites More sharing options...
imi Posted January 9, 2009 Share Posted January 9, 2009 Could be the bonnet switch (or one of the others), the Toad ones are pants in my experience, they don't like damp - pop the bonnet, pump the sprung switch up and down a few times and then close up to try again. 5 beeps is the "pre warn" feature I think, tells you something hasn't shut properly, can be set to 2 beeps too though - usually ends with the alarm going off though so maybe I'm talking crap again. Quote Link to comment Share on other sites More sharing options...
michael Posted January 9, 2009 Share Posted January 9, 2009 Crikey, something went in and stayed in, I'm getting better Quote Link to comment Share on other sites More sharing options...
DannyB Posted January 10, 2009 Share Posted January 10, 2009 Any luck fella? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 10, 2009 Author Share Posted January 10, 2009 Forgot about it today and to cold outside now. Quote Link to comment Share on other sites More sharing options...
supradriver Posted January 10, 2009 Share Posted January 10, 2009 mine will beep once one day then a few times the next. not sure why, just take it as it comes now. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2009 Author Share Posted January 17, 2009 It was thew bonnet switch, couple of washers under it to raise it up a tad and all fixed, cheers guys. What a loverly day out, gonna have to go for a blam in a min. Quote Link to comment Share on other sites More sharing options...
