how much stopping power to the back
supra_si
How much force % wise is placed thbrough the back whilst braking, basically having just seen the state of my front pads im wondering if its more to the back than front.
also when changing the back pads, do i need a special tool to wind the rear piston back or is it a push type like the front.
More stopping power at the front. Thats the reason why the discs and pads are bigger on the front. Think about a bike, if you hammer the rear brake your bike will skid, if you hammer the front it will throw you over the handle bars. The brakes have to be balanced so that a lot more stopping force is at the front to prevent skidding as much as possible.
Push type like front. AFAIR it's around 20% on rear.
AIUI, the amount of rear braking going on will vary depending on grip conditions, but it should always be significantly less than the work the front is doing.
It's important to keep a balance between front/rear brake setups, so this approximate ratio of F:R effort (and I always thought it was more like 60:40 but that's just a guess TBH) is maintained; have you got stock brakes front and rear, or has either end been uprated?
yeh i did think about it pal, i was just asking as im wondering why ppl are upgrading their rear brakes more often than their fronts, i did think the front would take more stick
Upgrading the rears? Everyone i know upgrades the fronts. Rears aren't AS important but its good to do the rears as well.
You can actually decrease the total braking ability by upgrading the fronts alone. I'll see if I can find an excellent post by CW from many years ago that I stumbled across recently...
edit here we go, read this.
Controversial I know, but people shouldn't mess with "upgrading" their brakes (especially just the front brakes) unless they totally understand what they're doing IMHO.
Edited by SteveR (see edit history)
If you have drilled/vented disks, and all you're suffering is a bit of corrosion built up, just scrape it out with a screwdriver or allen key.
there is no need to replace your brake disks unless they are past their useful life (i.e. the surface is too thin)
Makes perfect sense, i didn't read it all though... just the bit on the rear brakes. I was thinking along those lines myself. In my head i had it that the front would lock far too early and the rear brakes would be doing next to nothing.
