Another PC question
Digsy
I have a bit of software which is on *ahem* "permanent trial".
Keeping it in this state means that every so often I have to make a small tweak to the registry, which is a bit fiddly. There is a key under HKEY_CLASSES_ROOT that needs deleting if it is present.
I was wondering if there was a way to write a simple script file which made the change every time Windows starts up or shuts down, to save me having to?
I already have a backup script run on shutdown, so I know how to tell Windows to schedule it. I just don't know the script syntax for changing the registry.
Can you not export the registry settings and then add the export file to your 'start up'..?
I think you'll have to click 'OK' when it updates the reg, but probs better than manually doing it?
My simplistic solution anyway... I'm sure some of the JustGav/Carl0s style boffins will be along in a minute :D
Cheers guys. I actually got off my backside and did a Google search. Its actually a load easier than I thought it would be.
The command is:
reg delete hkcr\
To make it run silently, this becomes:
@echo y| reg delete hkcr\
I have added it the the shutdown scripts under group policies. Job done! :)
