Lance's Recommended Alignment
Sharpie
Hi,
I have my car going to get the alignment done tomorrow at my local dealer and will provide them with Lance's recommendation but, I see that they are all in degrees apart from the last one - Rear Toe IN 1.0mm.
So If:
0.080 is 2mm
0.120 is 3mm
What is 1.0mm in degrees ?
Or will Toyota be OK with this measurement ?
Thanks
From MKIV.com
1. What is a Good Street/Lance W. Alignment?
Front:
Camber - 1.0
Caster + 5.0
Toe 0.00
Rear:
Camber -1.5
Toe IN 1.0 mm
The Front and Rear Toe are critical to tire wear, even small deviations from spec may cause unusual wear patterns or excessive wear.
