gearbox swaps and compatibility
dr_jekyll
hi all, i was just wondering if anybody can lend there knowlage in regardes to gearboxes.
I have a w58 5 speed manual at the moment. Will the r154 fit straigt onto the 2jz with the same clutch and prop ect.
secondly dose the 154 come from the mk3 turbo, the 1jz soarer or both?
and finally apart from being stronger than the w58 how dose the 154 compair in terms of ratio and performance ,
thanks
Edited by dr_jekyll (see edit history)
I have a W58 5 speed manual at the moment. Will the R154 fit straight onto the 2JZ with the same clutch and prop etc?
Definitely a different clutch, and, I think, a different flywheel. Not sure about the prop, but it's fairly cheap to have one custom made anyway.
Secondly, does the 154 come from the Mk3 turbo, the 1JZ Soarer, or both?
Both. It's used on the Mk3 3-litre turbo (bellhousing won't fit a JZ), and on any manual 1JZ-GTE (Soarer, Mk3 Supra, Chaser/Mark II/Cresta). You won't find a 1JZ 'box in the UK, though.
