Superlite Coupe (SL-C)
michael
Rather nice looking IMO, should be quite rapid with the twin turbo Lexus V8 option too.
http://www.superlitecars.com/index.html
http://www.superlitecars.com/img/SL-C_01_large.jpg
http://www.superlitecars.com/img/SL-C_02_large.jpg
http://www.superlitecars.com/img_coupe/fullsize/rcr_coupe_2_fs.jpg
More on a similar theme:
http://race-car-replicas.com/
Any prices?
*clicks link again*
Yup ;)
http://www.superlitecars.com/coupe_spec.html
Rolling Kit Package: $43,995
Chassis
Aluminium Tig welded
6-point roll cage utilising DOM CNC bent seamless steel tubing
Left-Hand or Right-Hand Drive
Engine bay will accept any longitudinal engine trans package
Seat Belt mounts included
Suspension
CNC billet aluminum unequal length upper and lower arms front & rear
CNC billet aluminum uprights front & rear
Pushrod rear suspension
QA1 Aluminum Double Adjustable Shocks - truly independent double adjustable with 24 compression & 24 rebound adjustments with evenly spaced valving changes.
QA1 Springs
Steering
Full Electric Tilt & Adjustable in/out Steering Column
Collapsible steering column
Quick release steering wheel
Brakes
6 piston calipers front & rear, 330mm 2 piece vented & slotted rotors on front, 300mm 2 piece vented & slotted rotors on the rear
Triple pedals in stainless steel with master cylinders and brake bias adjuster
CV joint stub axles
Stainless steel brake lines with Braided flexible lines
Cooling & Fuel
Aluminium radiator
Twin electric fans
Stainless steel cooling tubes
15 gallon(60lt) fuel tank mid mounted behind seat per Le Mans spec
Wheels
Front: 18x9.5 multi-spoke aluminum
Rear: 18x11 multi-spoke aluminum
Note: Tires supplied by customer
Electrical
Digital Dash 2 Pro+ with data logging, 2-axis G-sensors, infra-red lap timer receiver & optional GPS for track
Headlights, tail lights, indicators
Mirrors with LED high mount turn signals
20 circuit colour coded wiring harness
Wiper Package
Interior
Production car style dash moulding
Cable gear shifter
Custom fiberglass seats
Functional roof scoop feed cabin with aircraft style vents
AC system with heater
Windows can be supplied so that they will hinge down or completely fixed
Accomodates up to 6' 4" driver
Body
High quality gelcoat body panels with gloss finish
Stainless steel alignment pins
All body parts are fitted and aligned
Vertical opening doors
DOT windscreen
Hinged rear glass for engine access
Lexan for side windows & headlight covers (cut to size with edges polished)
All required handles and latches
4 - 4.5 inches ground clearance with removable side skirts and front spoiler for track package
Supplied with front spitter, side skirts, rear diffuser & chassis mounted adjustable rear wing
Choice of gelcoat colours for body: Light blue, Dark Blue, Red, Yellow, Black, White
Dimensions
Width: 74 inches (1880mm)
Height: 43 inches (1092mm)
Length: 168 inches (4267mm) - excluding rear wing
Weight: less than 1000kg's depending on options & engine choice
All of the above is included in the standard package
Optional Extras
Handbrake Assembly
Full trimmed production quality interior
FIA bladder style fuel tanks
Sway bars front & rear
Wheels –18x10(F), 18x13® rotory forged aluminum. Available in painted or satin finish.
So $43,995 plus one of Cowboy Beebop's twin turbo V8s and a gearbox... not quite Fiesta money sady but probably a relative bargain for the grins it will produce.
That's pretty damn good actually.
Crazy idea: rent house with garage in Florida for 1 month, spend the time building the car, then put it on a boat back to UK once done.
Customer has to buy the tyres too I notice... and for a V8TT you'll be needing custom intercooling parts too. Still, probably still sub-£50k
