JamesC Posted January 6, 2009 Share Posted January 6, 2009 After finishing a night-shift and returning to the car i found that both the doors had frozen shut when i finally got in and cleared all the windows, glad that i could eventually go home, i tried to pull away only to realise that the handbrake had frozen on as well Is the old trick to put Vasline on the rubbers around the door to stop it freezing shut? And what about the handbrake? Change the rubbers underneath? Quote Link to comment Share on other sites More sharing options...
Jake Posted January 6, 2009 Share Posted January 6, 2009 It was Minus 9.5 Centigrade on the way to work this morning ! Quote Link to comment Share on other sites More sharing options...
MrDriver Posted January 6, 2009 Share Posted January 6, 2009 -12C this morning bbrrrrr Handbrake is a big nono, just put it in 1st gear! Hope you aren't parked on a steep hill... Quote Link to comment Share on other sites More sharing options...
caseys Posted January 6, 2009 Share Posted January 6, 2009 I came out the gym this morning after a shower, hadn't dried my hair properly. On the little walk from the car park into work my hair had actually frozen solid... black spikey hair the Mother Nature way.. Have had my windows frozen a few times when getting up for work at 5am, it's amusing isn't it? Quote Link to comment Share on other sites More sharing options...
michael Posted January 6, 2009 Share Posted January 6, 2009 Only -5 at 8am here today. Is the old trick to put Vasline on the rubbers around the door to stop it freezing shut? And what about the handbrake? Change the rubbers underneath? You'll rot the door rubbers if you do that. Halfords do a product that will help with this and also feed the rubbers, just don't use too much and spray onto a cloth rather than the car because it makes a mess of the glass / paint: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219033_langId_-1_categoryId_165705 Personally I use this: http://www.cleanyourcar.co.uk/interior/303-aerospace-protectant/prod_366.html If the handbrake is freezing it's probably more sensible to change the cables, I used to get this on my MR2 a lot, the rubber boots at the handbrake side perished and allowed water in, it would take a full day to defrost sometimes so you had to remember to park with the handbrake off. Quote Link to comment Share on other sites More sharing options...
Animal Posted January 6, 2009 Share Posted January 6, 2009 Well, there was a generous coating of ice on the INSIDE of my bedroom window at the B&B this morning cos the heating broke. The plumber had better get it fixed today. Quote Link to comment Share on other sites More sharing options...
JamesC Posted January 6, 2009 Author Share Posted January 6, 2009 Have had my windows frozen a few times when getting up for work at 5am, it's amusing isn't it? Yes, very Only -5 at 8am here today. You'll rot the door rubbers if you do that. Halfords do a product that will help with this and also feed the rubbers, just don't use too much and spray onto a cloth rather than the car because it makes a mess of the glass / paint: http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_219033_langId_-1_categoryId_165705 Personally I use this: http://www.cleanyourcar.co.uk/interior/303-aerospace-protectant/prod_366.html If the handbrake is freezing it's probably more sensible to change the cables, I used to get this on my MR2 a lot, the rubber boots at the handbrake side perished and allowed water in, it would take a full day to defrost sometimes so you had to remember to park with the handbrake off. Cheers Michael! I'll go and get some of that lube later on today I used to have a Fiat Coupe and the exact same thing happened on that, frozen doors and handbrake. Quote Link to comment Share on other sites More sharing options...
Nic Posted January 6, 2009 Share Posted January 6, 2009 Only 23°C here today Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted January 6, 2009 Share Posted January 6, 2009 Only 23°C here today http://www.kolobok.us/smiles/light_skin/sun_bespectacled.gif You must be Freezing, poor sod Quote Link to comment Share on other sites More sharing options...
Animal Posted January 6, 2009 Share Posted January 6, 2009 Waits for group buy on sunshine Quote Link to comment Share on other sites More sharing options...
hoff Posted January 6, 2009 Share Posted January 6, 2009 Well, there was a generous coating of ice on the INSIDE of my bedroom window at the B&B this morning cos the heating broke. The plumber had better get it fixed today. And there's me thinking ice on the inside of the supras rear window was bad:blink: Quote Link to comment Share on other sites More sharing options...
marc_p Posted January 6, 2009 Share Posted January 6, 2009 I came out the gym this morning after a shower, hadn't dried my hair properly. On the little walk from the car park into work my hair had actually frozen solid... black spikey hair the Mother Nature way.. I bet that actually looked quite cool though:cool: My civic hasn't started the past 2 mornings as it has been too cold for it so I have had to take the Supra to work which has not made for an enjoyable ride especially seeing as the tires are not very good in the cold/wet. Quote Link to comment Share on other sites More sharing options...
scotty supra Posted January 6, 2009 Share Posted January 6, 2009 (edited) aa Edited August 13, 2009 by scotty supra (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest larteyc Posted January 6, 2009 Share Posted January 6, 2009 Well at least it aint just me! Went out, both doors frozen shut and couldn't even turn the key in the lock on the drivers side! Quote Link to comment Share on other sites More sharing options...
