Want to raise the front end of my supra
Guest CoolsBlue
Now, i have stock springs...can it be raised?
It seems lower than stock in your garage pic..........if you want to compare ride heights then if you post up the ground to say front subframe and sill areas i will do the same on my (higher looking) definitely stock sprung car.
Are the three spoke alloys 17"?
Guest CoolsBlue
Yup 17's which is why it looks low, when it was on the stock kit it looked pretty normal to me, got pictures to compare!!:)
Hey dude ;)
Just noticed your in Northants'. Ashbph set me up with some great new Tein Super streets (coilovers). He's in north Leicester - not that far for you - has his own garage now, and I'm sure he'd be happy to have a look at your supra, in the metal so to speak, and give you some first hand advice :) Perhaps just replacing the springs would be enough without shelling out lotsa dosh. Drop him a PM
Lx
can't post any at work will do later.
I asked about them being 17" as the photo of mine i looked at, the line from top on the front bumper is above the level of my stock 17" wheel rims, its an inch or so up into the tyre. On yours the bumper would seem to line up with the top of the wheel rim, suggesting yours is lower.
