Tom Posted January 3, 2009 Share Posted January 3, 2009 This thread on sf has been going since 2006 but i've just spotted it StSupDog said: OK, so I originally wanted to just switch out the Auto console panel for the 98 6spd painted Flat Black to match my other pieces and keep the stock Shifter knob.... but, My Brother (TTSupDog) showed me this "MOMO" Shift knob and already test fitted it on his Supra but, Had the knob way too low for my taste and he was going to mount the “OD” button somewhere else on the panel...He had already located the “TRD” epoxy dome decal but, he was concerned on the size..I would later fix that problem by removing a plate and painting the surrounding area in black High temp paint.. After looking at it and seeing how it would resemble my TRD Steering wheel (I had it Re Done in Fresh Leather w/ perf sides)... I couldn't resist..I just didn't like the idea of Screwing up a Brand New $90 knob.... But, I bought it anyway and began to think of how I was going to put the "OD" button to work on it... Below is the finish result.. First I removed All of the factory auto shifter pieces then I took off the "MOMO" epoxy dome decal and rest plate of the new Knob... tapped it with a Drill Press...Modded the "OD" button to fit, Dremeled grove canals for the wires, Painted inner ring black, Shaved the "OD" Button Flat, blah blah blah... you get the picture.. P.I.T.A.!! End result: The "TRD" button you see is the "OD"...and I love it! ... It feels Great..It feels as it should, like a sports car! I still thinking of getting the Allen key screws for the holes..... In Park In Neutral Close up of the "OD-TRD button" Vandie said: So, this thread has inspired me to do the same, but with mine I have retained the shift lock out, and simply moved the O/D button to a new position. New manual dash panel to come soon aswell. Simply push down to un-lock the shifter Vandie said: to solve the problem of people not knowing where the gears are, I made this subtle sticker. The gears with lockout are underlined Quote Link to comment Share on other sites More sharing options...
Tom Posted January 3, 2009 Author Share Posted January 3, 2009 this is pretty neat too, POLL OPTIONS: Trying to make up my mind: (A) Keyfob w/hidden key + smart start button = You get a Keyfob with a hidden blank key. Fob communicates to box in car. Once your 2-3 feet from the car, it automatically locks/unlocks the doors and enables the start button. It also allows anti-carjacking. If the fob is not in the car within 30 seconds of you starting it OR opening then closing the door, cuts the ignition via the start button. (B) Smart start button ONLY = Just the button and circuitry. It will need a signal from another alarm to enable itself and let you start your car. You would use your alarm to lock/unlock the doors. This is the best option for those of us who have a nice COMPUSTAR alarm system with the 2-way pager. The hidden keyfob is nice, but you'll end up carrying to large fobs everywhere you go. © Automatic lock/unlock as you approach the car = Best convenience if you choose the keyfob option, but may become annoying if your working on your car. You can cover the keyfob in aluminum wrap, turn off the RFID via a button, or keep the key near the car. (D) Must touch car to lock/unlock = Small hidden sensor near glass. Keyfob enables this sensor. You touch sensor to lock/unlock the doors. Issue here is you *can* leave the fob in the car and it can still lock on you. UPDATE: 07 / 23 / 08 Video PART 2: Full operation: http://www.youtube.com/watch?v=2n6F-owxgyY Here's a topic: Youtube VIDEO showing my progress-> http://www.youtube.com/watch?v=iTDHLUd_lls Talk amongst yourselves... ------------------------------------------------- Final button Integrated Key Fob with internal Supra Key and smart keyless circuitry - Custom cut supra key inserted into keyfob. OEM Infinit fob guts tossed in favor or custom circuitry. Only one button works for emergency lock/unlock. Prototype unit - fairly complete minus the button. Circuit progress ---------------Original Post--------------------- I'm almost done working on a product and am looking for any interested parties. First off, these things generally cost $2000-$3000 if you buy all the parts seperately. I can probably get this down to a few hundred dollars. What: Auto push button start with auto-detect keyfob. Key the fob in your pocket. Get close to your car, open your doors w/o a key. Get into your car, push the button, car starts. Key only needed for opening the door manually. Included: RFID fob - 128bit encryption, new code generated each time you walk away from the car. I haven't yet decided how to incorporate the Supra key inside (like most do). I may request you ship me a copy of your key so that I can create the key-in-fob desgn or supply a kit that allows you to cut your key and slip it in.. or send me a remote that you use (alarm remote) where I can insert the frequency detection guts inside for a clean design. Smart Push button - You push once, turns on accessories. Push again, turns them off. Anytime you put your foot on the brake and push the button, it cranks. Stops cranking after the tach signal reaches idle. Push again, turns off. The button will only function if the fob is in your car. I have yet to develop a column-lock solenoid if it can even be made. I may have to look at late-model toyotas to see if there is anything already available. If not, I can still offer this unit with the intention that the user resolves column-lock themselves. Theft concern: It will be component based. If your a thief and you know the supra wiring, a few cuts and twists you can start the car. I plan to include a seperate connection for the fuel pump. You can always use this system with your current alarm, so there is that option. I am looking at a few weeks for a test mule to be completed. As with anything, I would not be responsible for car theft, just like a turbo supplier isn't responsible for you dying due to excessive HP. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2009 Share Posted January 3, 2009 I do like the original TRD 'manual' looking gear knob during the first few photos, a lot! Quote Link to comment Share on other sites More sharing options...
Gazboy Posted January 3, 2009 Share Posted January 3, 2009 Very neat. Notice both cars don't have crappy aftermarket wheels on them. Quote Link to comment Share on other sites More sharing options...
Guest dangerousandy Posted January 3, 2009 Share Posted January 3, 2009 I do like the original TRD 'manual' looking gear knob during the first few photos, a lot! So do I!!!! I have a genuine TRD gearknob in my Celica (which I shall be fitting to my GA70 Supra soon) but I am liking the look of the Momo gearknob!! Did that come with the TRD logo or has it been modified? Where can I get one from!!!! Quote Link to comment Share on other sites More sharing options...
stupra Posted January 3, 2009 Share Posted January 3, 2009 I like it, but where is the MANU button ?, or did I just miss that in the write up ?. Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2009 Share Posted January 3, 2009 I like it, but where is the MANU button ?, or did I just miss that in the write up ?. Ooh well observed. I couldn't do without my manu option! Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2009 Share Posted January 3, 2009 Nice find, what car is the bottom steering wheel from? looks nice and chunky. Quote Link to comment Share on other sites More sharing options...
Thorin Posted January 3, 2009 Share Posted January 3, 2009 So that first mod is for auto owners wanting to make it look like they bought a proper gearbox car? Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2009 Share Posted January 3, 2009 So that first mod is for auto owners wanting to make it look like they bought a proper gearbox car? Although the auto is great, the console in the cabin isn't the most attractive IMO, so with a little tweaking it could look better. Maybe it just needs a gear stick gaiter. Quote Link to comment Share on other sites More sharing options...
hiten55 Posted January 3, 2009 Share Posted January 3, 2009 Although the auto is great, the console in the cabin isn't the most attractive IMO, so with a little tweaking it could look better. Maybe it just needs a gear stick gaiter. dont think thats what he meant Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2009 Share Posted January 3, 2009 dont think thats what he meant I know, and I'm rising above his condescending comment, and trying to offer a possible solution. Who wants a manual anyway? They are so last century Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted January 3, 2009 Share Posted January 3, 2009 Not feeling it...engine start button? do i want my supra to be an easy target to get nicked? that shifter...looks crappy...the stock one looks much better imo waste of money tbh Quote Link to comment Share on other sites More sharing options...
hiten55 Posted January 3, 2009 Share Posted January 3, 2009 I know, and I'm rising above his condescending comment, and trying to offer a possible solution. Who wants a manual anyway? They are so last century actually come to think about it, the manual boys are probably just jelous cos they dont have an auto button, or an overdrive button or they could just be baffled by the mysterious and sacred "red Button" that is often discussed Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted January 3, 2009 Share Posted January 3, 2009 Not feeling it...engine start button? do i want my supra to be an easy target to get nicked? that shifter...looks crappy...the stock one looks much better imo waste of money tbh Maybe you should've read the bit where it explained the blank key, and sensor thingy that would only work if they were brought within a few feet of the car. So it could be harder to nick if you can't find somewhere to start the ignition. Quote Link to comment Share on other sites More sharing options...
Blackie Posted January 3, 2009 Share Posted January 3, 2009 Thats sweeet Quote Link to comment Share on other sites More sharing options...
SteveR Posted January 3, 2009 Share Posted January 3, 2009 I quite like that fob + button replacement, but I think mainly because I appreciate the effort that chap has gone to. I'll stick with using a key for now. Quote Link to comment Share on other sites More sharing options...
Ewen Posted January 3, 2009 Share Posted January 3, 2009 (edited) Nice find, what car is the bottom steering wheel from? looks nice and chunky. Thats a later facelift wheel Jamie. Earlier facelifts still came with four spokes, then changed over to these toward '98 as far as I have seen. The Tiptronic wheel is identical apart from the shift buttons. Heres one, hope you dont mind Jim C http://www.mkivsupra.net/vbb/attachment.php?attachmentid=74027&d=1208163637 Edited January 3, 2009 by Ewen Wrong year listed (see edit history) Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2009 Share Posted January 3, 2009 Thats a later facelift wheel Jamie. Earlier facelifts still came with four spokes, then changed over to these toward '98 as far as I have seen. The Tiptronic wheel is identical apart from the shift buttons. Heres one, hope you dont mind Jim C http://www.mkivsupra.net/vbb/attachment.php?attachmentid=74027&d=1208163637 Ahh i see, the one in Tom's pic has Red stitching, would go nice with my seats;) i take it that has been retrimed. Quote Link to comment Share on other sites More sharing options...
Branners Posted January 3, 2009 Share Posted January 3, 2009 somebody did a similar kit for the auto cars quite a while ago. Here is a link to the thread. I dont think there is anybody left on the forum who had one fitted but the kit seemed to work okay. The guy that did them moved on to Ferraris and so was never seen again. http://www.mkivsupra.net/vbb/showthread.php?t=372&highlight=gear Quote Link to comment Share on other sites More sharing options...
The Raven Posted January 3, 2009 Share Posted January 3, 2009 Give, i like the auto stuff alot Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted January 3, 2009 Share Posted January 3, 2009 (edited) It may not be everyones taste but I like the starter button - is this from SF? is there more info on the actual product? did the guy finnish it to buy? Edit: I have contacted the maker and am awaiting some info... Edited January 3, 2009 by Sandy-m2 (see edit history) Quote Link to comment Share on other sites More sharing options...
JamesF Posted February 17, 2009 Share Posted February 17, 2009 Any links to the original SF auto shifter thread? Cant find it on SF Quote Link to comment Share on other sites More sharing options...
Tom Posted February 17, 2009 Author Share Posted February 17, 2009 http://www.supraforums.com/forum/showthread.php?t=379401 Quote Link to comment Share on other sites More sharing options...
JamesF Posted February 17, 2009 Share Posted February 17, 2009 You sir are a prince! Quote Link to comment Share on other sites More sharing options...
