RamzisX Posted January 3, 2009 Share Posted January 3, 2009 Hi guys, need your advise again, is there any problems to fit shocks/springs kit from tt to na supra? thanks Link to comment Share on other sites More sharing options...
Konrad Posted January 3, 2009 Share Posted January 3, 2009 No there will be no problems with this, straight swap Link to comment Share on other sites More sharing options...
RamzisX Posted January 3, 2009 Author Share Posted January 3, 2009 cheers mate Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 3, 2009 Share Posted January 3, 2009 It'll fit, but the car will sit a bit higher, especially at the front, and be quite a bit stiffer. Link to comment Share on other sites More sharing options...
RamzisX Posted January 3, 2009 Author Share Posted January 3, 2009 It'll fit, but the car will sit a bit higher, especially at the front, and be quite a bit stiffer. oh cool thats what i need Link to comment Share on other sites More sharing options...
JustGav Posted January 3, 2009 Share Posted January 3, 2009 It'll fit, but the car will sit a bit higher, especially at the front, and be quite a bit stiffer. Chris, for goodness sake, don't ask what wheels he has Link to comment Share on other sites More sharing options...
barneybrendan Posted January 4, 2009 Share Posted January 4, 2009 i just bought tt front shocks and springs for mine ,fitted them and the front looked stupid way to high.so used the gas shocks with n/a springs.when you put springs side by side you can see the difference. Link to comment Share on other sites More sharing options...
RamzisX Posted January 5, 2009 Author Share Posted January 5, 2009 i just bought tt front shocks and springs for mine ,fitted them and the front looked stupid way to high.so used the gas shocks with n/a springs.when you put springs side by side you can see the difference. thanks, is there any difference if its UKspec or Jspec? Link to comment Share on other sites More sharing options...
hoff Posted January 5, 2009 Share Posted January 5, 2009 It'll fit, but the car will sit a bit higher, especially at the front, and be quite a bit stiffer. Chris is that due to the springs alone or the shocks too? Posted via Mobile Device Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 5, 2009 Share Posted January 5, 2009 Springs alone, the spring seat heights on stock N/A and TT dampers are the same. Link to comment Share on other sites More sharing options...
hoff Posted January 5, 2009 Share Posted January 5, 2009 I wish I had seen this a few minutes ago before posting in the wanted section. I Should use the search properly. Thanks for that Chris. I'm running Tein Na springs so thats all good for me. Posted via Mobile Device Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 5, 2009 Share Posted January 5, 2009 See my post in the Wanted section. Link to comment Share on other sites More sharing options...
hoff Posted January 5, 2009 Share Posted January 5, 2009 Replied. Thank you Chris. Posted via Mobile Device Link to comment Share on other sites More sharing options...
