TNT Posted January 1, 2009 Share Posted January 1, 2009 Went out today for a quick blast, whilst out I noticed a scraping sound, stopped and found a small plate under drivers side, about level with the wheel had come loose. Plate is about 6" x 4" slightly curved and has a barrel with a cable running through it. With my limited knowledge I would say its around the bottom of the auto gearbox? No reason why it should have dislodged. Not able to get a picture until the morning, real concern is that there was a trace of oil on my fingers after having lodged it back into place to get home. Everything seems to be running fine. Quote Link to comment Share on other sites More sharing options...
TrickTT Posted January 2, 2009 Share Posted January 2, 2009 Shield for fuel filter? It will be drilled if it is. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 2, 2009 Share Posted January 2, 2009 Fuel filter is on the other side though. Quote Link to comment Share on other sites More sharing options...
TNT Posted January 2, 2009 Author Share Posted January 2, 2009 Hopefully get it looked at this morning, if it is the shield for the fuelfilter what would the cable be running through the barrel? Let you know later. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 2, 2009 Share Posted January 2, 2009 This has happend to me i thought it was just a cover for something, ive gt it lay in my porch been off for about 2 month now hope its nothing serious i thought it was just the car helping shed some weight lol Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted January 2, 2009 Share Posted January 2, 2009 Do the auto boxes have the inspection plates like the manuals do? They are slightly curved, can't remeber if they are tethered though. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 2, 2009 Share Posted January 2, 2009 Hopefully get it looked at this morning, if it is the shield for the fuelfilter what would the cable be running through the barrel? Let you know later. What do you mean by "barrel"? A photo of the part would get your answer quickest. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted January 2, 2009 Share Posted January 2, 2009 It won't be the fuel filter shield, that's on the passenger side. The autos don't have an inspection point, just a rubber cap which fits into the block to gain access to the torque converter bolts. Does the plate have a grommet fitted to it and the cable runs through this? Quote Link to comment Share on other sites More sharing options...
TrickTT Posted January 2, 2009 Share Posted January 2, 2009 Only thing I can think of on the drivers side is the cat temp sensor then. Quote Link to comment Share on other sites More sharing options...
w41k3r Posted January 2, 2009 Share Posted January 2, 2009 yeah i thought it was the cover for the temp sensor from memory it had like a silver round bracket where a wire maybe steel line ran threw it but im sure its where the sensor was mine fell down and was haanging from the silver line. the full item is a piece of curved metal bwt 6 inch by 6 inch then the little round bracket off that Quote Link to comment Share on other sites More sharing options...
Konrad Posted January 2, 2009 Share Posted January 2, 2009 Only thing I can think of on the drivers side is the cat temp sensor then. It was cat temp sensor indeed. Shield removed as it was just piece of rusty, damaged metal Quote Link to comment Share on other sites More sharing options...
TNT Posted January 2, 2009 Author Share Posted January 2, 2009 Thanks to Konrad, I learn something new again, it looked a lot simpler in daylight. Thanks for all the advice. Quote Link to comment Share on other sites More sharing options...
