Guest rustybolt999 Posted January 1, 2009 Share Posted January 1, 2009 i have got the same problem as benyon has with his brakes the front brakes come on the pressure through the pedal gets hard and i can not move the car leave it for half an hour and the pressure has gone does not happen all the time help me please Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 1, 2009 Share Posted January 1, 2009 Faulty master cylinder or wrongly adjusted master cylinder pushrod. *UNLESS* only one front caliper locks on, in which case suspect a collapsed flexi hose to that caliper. Quote Link to comment Share on other sites More sharing options...
Guest rustybolt999 Posted January 1, 2009 Share Posted January 1, 2009 thanks for the info 277 pounds for a new one o well hey ho Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 1, 2009 Share Posted January 1, 2009 thanks for the info 277 pounds for a new one o well hey ho If Toyota or the aftermarket list a seal kit, fitting that and a thorough clean out and blow out with an air line should fix it for far less. Just s trip and thorough clean might work, but it's bad practice to re use old seals, strictly speaking. The fluid return hole will be bunged up. Quote Link to comment Share on other sites More sharing options...
Guest rustybolt999 Posted January 2, 2009 Share Posted January 2, 2009 thanks iull let u know Quote Link to comment Share on other sites More sharing options...
colsoop Posted January 2, 2009 Share Posted January 2, 2009 You could try the MC push rod adjustment first, do you have access to the repair manuals ? There is a section in there about measuring and adjusting the MC push rod. Quote Link to comment Share on other sites More sharing options...
Guest rustybolt999 Posted January 4, 2009 Share Posted January 4, 2009 i have never touched the rod dont think its that its the fluid getting contaminated because i changed it 3 months ago and it was alright its just started again Quote Link to comment Share on other sites More sharing options...
