Water Neck/Elbow Modification Question - Help
dandan
Those of you who have modded your water elbow...
Can you tell me what size the holes are that are left when you pull the standard barb/pipe pieces out? I'm trying to find a fitting to thread in there but need to what to tap it to first.
The reason I am asking and not doing is I am getting evrything up together forst before commencing!
Cheers
Dan
I want to tap them both, blank one and then feed water to the DBB cartridge off the other.
I'm just trying to work out what thread I can get away with:
#4AN would be a 7/16" UNF and that would need something like a clean 9.75mm hole to tap.
M12x1.25 would be more like a clean 10.75mm hole to tap.
Obviously the smaller the holes are the more meat left in the original part for integrity.
Edited by dandan (see edit history)
  • 1 month later...
