200k km 1JZ-GTE service
Stealth-1JZ
im comeing near the 200K km mark and was looking for advice on the service.
the cars geting maped [EMB] around the same time for the 1st time aswell.
currantly she is runing 1bar [14.5psi] after the map the E-01 will be set to 16psi hopefully.
bar the oil,oil filter,plugs,TB,water pump,atf and a suspension/under car check what else should i plan for ?
stuf i know that doseant need doing as its been done recently
air filter,fuel filter,break pads/fluid and disks,coil-packs,rocker gaskit and AC [its shot anyway]
