Visual Markings on Hks cams
Ryan.G
A friend sent me down a set of cams which he was sold as HKS 256 cams a while back but after viewing them today im not so sure they are HKS units but Stock.
I have attached some pics. Can anyone else comfirm?
There are no duration markings on the end of the cam and the Hex turning part of the cams are in the stock location as well compared to them being near the end on the HKS units.
Here are some pics of HKS units i found on here
I don't remember my HKS cams having the duration stamped on the end like the first pic, but like the others I'm pretty sure they had HKS stamped on somewhere. I remember they had something scratched on the hex part like Marty's too.
You could probably measure them with a vernier or something to get the lobe height. If you measured the narrowest point and widest of a lobe and subtract one from the other that would give you the lift.
We think a like. Measured the height of the lobe at 44.32mm and then the base circle at 36.18 on No:1 Cam.
So 44.32 - 36.18 = 8.14mm
*runs off to check Jspec cam lifts*
