Ryan.G Posted December 30, 2008 Share Posted December 30, 2008 A friend sent me down a set of cams which he was sold as HKS 256 cams a while back but after viewing them today im not so sure they are HKS units but Stock. I have attached some pics. Can anyone else comfirm? There are no duration markings on the end of the cam and the Hex turning part of the cams are in the stock location as well compared to them being near the end on the HKS units. Here are some pics of HKS units i found on here Quote Link to comment Share on other sites More sharing options...
Steve Posted December 30, 2008 Share Posted December 30, 2008 IIRC the HKS cams have 'HKS' stamped on them on the shaft about halfway down. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted December 30, 2008 Author Share Posted December 30, 2008 IIRC the HKS cams have 'HKS' stamped on them on the shaft about halfway down. I think the same but my picture memory is not the best Quote Link to comment Share on other sites More sharing options...
Steve Posted December 30, 2008 Share Posted December 30, 2008 I do have my set of J spec cams in the garage roof, i will have a look at them in a bit. Quote Link to comment Share on other sites More sharing options...
Luka-P Posted December 30, 2008 Share Posted December 30, 2008 They look like stock JSpecs. I wondered what the 2JT stood for when I was refitting mine. Quote Link to comment Share on other sites More sharing options...
Marty Posted December 30, 2008 Share Posted December 30, 2008 (edited) my set of hks cams had hks stamped on them, as well as the duration. I have pic's but they are of poor quality, but you can see what you need to. I think your mate has had his pant's pulled down there.. Edited December 30, 2008 by Marty (see edit history) Quote Link to comment Share on other sites More sharing options...
SimonB Posted December 30, 2008 Share Posted December 30, 2008 I don't remember my HKS cams having the duration stamped on the end like the first pic, but like the others I'm pretty sure they had HKS stamped on somewhere. I remember they had something scratched on the hex part like Marty's too. You could probably measure them with a vernier or something to get the lobe height. If you measured the narrowest point and widest of a lobe and subtract one from the other that would give you the lift. Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted December 30, 2008 Author Share Posted December 30, 2008 I don't remember my HKS cams having the duration stamped on the end like the first pic, but like the others I'm pretty sure they had HKS stamped on somewhere. I remember they had something scratched on the hex part like Marty's too. You could probably measure them with a vernier or something to get the lobe height. If you measured the narrowest point and widest of a lobe and subtract one from the other that would give you the lift. We think a like. Measured the height of the lobe at 44.32mm and then the base circle at 36.18 on No:1 Cam. So 44.32 - 36.18 = 8.14mm *runs off to check Jspec cam lifts* Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted December 30, 2008 Author Share Posted December 30, 2008 They are indeed Stock Cams Quote Link to comment Share on other sites More sharing options...
Steve Posted December 30, 2008 Share Posted December 30, 2008 For future reference My J spec stock cams have 'No.1' and 'No.2' stamped on them. Also on the 'No.2' shaft, in the middle it has '2' on one side and 'JZ' on the other. That is all the markings i can see on them. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted December 30, 2008 Share Posted December 30, 2008 100% both my 264's and 272's had HKS stamped on them Quote Link to comment Share on other sites More sharing options...
