Name That Part!
Luka-P
Hey Up Guys,
I'm nearly done with the engine. It's back in and pretty much everything is hooked up. I just need to figure out where these parts go. I have an odd feeling they go under the intake in an annoying place which I won't be able to get to very easily!
Cheers!
The top bit looks like the vac pipes that feed the Pressure sensor, fuel pressure regulator etc. (with a few added bits of pipework though)
The bottom part fits between the plenum and the block (a support) the pipes on it connect to the pressure tank IIRC
Your dipstick also attached to the plenum support, you may find it's a bit wobbly and prone to the whole tube falling out without it :)
The hose with the T-pieces in looks like OEM hose and OEM clamps used with the non-stock T's in order to feed a reference to a couple of extra things. The diameter of the hose is too thick to be the MAP sensor/FPR one. Could live anywhere - where are you missing hoses? :)
-Ian
