imi Posted December 26, 2008 Share Posted December 26, 2008 Question: as I have RLTC in my car and I have disconnected the toyota crappy traction system, I was thinking of using the TRACTION button as a push to make button to power my CARPC. Can this button be used as a push to make? Quote Link to comment Share on other sites More sharing options...
Steve Posted December 26, 2008 Share Posted December 26, 2008 I dont beleive the switch actually stays locked in the 'made' position. I think it just sends a signal to the ECU which does all the switching. Have never checked this with a meter to confirm though. Quote Link to comment Share on other sites More sharing options...
imi Posted December 26, 2008 Author Share Posted December 26, 2008 I see. bearing in mind that my ECU is an AEM ECU and I dont really care about the stock traction system, should I go ahead and butcher the switch or not? Quote Link to comment Share on other sites More sharing options...
Steve Posted December 26, 2008 Share Posted December 26, 2008 I see. bearing in mind that my ECU is an AEM ECU and I dont really care about the stock traction system, should I go ahead and butcher the switch or not? It would have gone to the TRAC ECU not the main one. You could always get a blank plate like the others and cut your own switch into the plate. I did this for a switch for the aerial as my head unit wouldn't operate it correctly. Quote Link to comment Share on other sites More sharing options...
imi Posted December 26, 2008 Author Share Posted December 26, 2008 like the simple idea......know anyplace that would sell a switch that fills the space? Quote Link to comment Share on other sites More sharing options...
Steve Posted December 26, 2008 Share Posted December 26, 2008 (edited) I got a little one from Maplins. The black version if this http://www.maplin.co.uk/Module.aspx?ModuleNo=34857 Obviously this was drilled into the blank plate i got from Jezz. HTH Edited December 26, 2008 by Steve (see edit history) Quote Link to comment Share on other sites More sharing options...
Pig Posted December 26, 2008 Share Posted December 26, 2008 Im not totally sure what your asking but mine isnt even connected if that helps. Quote Link to comment Share on other sites More sharing options...
