Fuel pressure question
bignum
I need to know what should happen to fuel pressure after the engine is shut off, ie how long and what pressure compared to static.
Mine drops to about 2 psi after 5 seconds or so which i reckon is not helping my hotstart problem at all, cheers.
Oh, merry christmas all.
What set up have you got?
When you try the next hot start you could turn ign on for about 2 secs then off for about the same....then repeat maybe three times. Then crank straight away.......fuel pressure would have definitely build up from the pump priming during those initial "ign on" events. See how that fares....might give you another piece of info for diagnosis
really wouldn't think it would effect hot start but mine holds pressure for 20 ish minutes (i've never timed it), it may indicate some other problem in the fuel system, has it just developed this problem ? or is it an ongoing issue with the ecu
i think all ecu's (aftermarket and stock) have a hot start function and it sounds like yours isn't setup, do you have an AFR gauge if so you could watch what you are getting whilst trying to fire it up and post it here, it wont mean jack to me but i'm sure some ecu type would be able to confirm whats what :)
It should hold the rail pressure for many many minutes, if not hours. There should be a none return valve in the pump, and the injectors shouldn't bleed down, and the FPR should hold pressure. So it's basically a leak somewhere. It certainly won't help hot starting, low rail pressure can cause vaporisation. Leaky injectors cause flooding, blah balah.
I think i`m getting a vapour lock chris,as my hotstart problem only happens if the car is upto temperature and is left for half an hour or more, i`m going to find out which part of the system is at fault by clamping off the return to test the fpr then before the rail to test pump return valve and injectors,
cheers for the input guys
