Jellybean Posted December 24, 2008 Share Posted December 24, 2008 Gear Judge: Is how the AVCR identifies what gear you are in But how does it? I dont understand the setting can somebody please explain Example as in Avcr installation manual 1st: 140 2nd: 100 3rd: 070 4th: 050 5th: 040 What do this settings mean? Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 24, 2008 Share Posted December 24, 2008 Those are the rpm to speed ratios. It works out what gear you are in by revs/speed, but you train it first by driving at a set RPM in those gears. Can't remember the specifics, the instructions tell you how to set it up. A handy hint from supraforums, as the AVCr only has entries for 5 gears, is to treat your 6th as its 5th, your 5th as its 4th etc down to 2nd as 1st. You'll never need to trim 1st gear boost levels on these cars -Ian Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 24, 2008 Author Share Posted December 24, 2008 Those are the rpm to speed ratios. It works out what gear you are in by revs/speed, but you train it first by driving at a set RPM in those gears. Can't remember the specifics, the instructions tell you how to set it up. A handy hint from supraforums, as the AVCr only has entries for 5 gears, is to treat your 6th as its 5th, your 5th as its 4th etc down to 2nd as 1st. You'll never need to trim 1st gear boost levels on these cars -Ian Thank you Also found this very useful Supra specific artical http://www.mkivsupra.net/vbb/showthread.php?p=2216737#post2216737 Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 24, 2008 Share Posted December 24, 2008 Your link appears to point to this very same post Quote Link to comment Share on other sites More sharing options...
Jellybean Posted December 25, 2008 Author Share Posted December 25, 2008 Your link appears to point to this very same post My bad http://www.mkiv.com/techarticles/avc-r/advanced_tuning.html Quote Link to comment Share on other sites More sharing options...
